Printer Setup & Support Call 1-(805) 225-6690 For help We are 24 Hour Available Call Now For Help
On the screen of my Printer is written;Cannot Print,Read your User`s Guide on Troubleshooting. My Printer "BROTHER MFC-210C USB PRINTER is not printing.How do I resolve this problem?
unable to print see troubleshooting and routine maintenance chapter in Manual's Guideunable to print see troubleshooting and routine maintenance chapter in Manual's Guide
You can't post conmments that contain an email address.
The color option has to be given from the software you are using. Ex. if you are using Microsoft word, then when you select print, click on the advance settings option and you can select if you need color prints or grayscale/ black.
NOTE: If the printer has been powered OFF for a long period of time, the date and time may need to be reset when the printer is powered back ON.
Press the [Menu] button on the Control Panel until 'Machine Setup' is displayed on the top line of the Display Screen.
Press the [Left] or [Right] arrow button on the Control Panel until 'Date and Time' is displayed.
Press the [Enter] button on the Control Panel.
Refer to the table below to enter the current date and time using the numeric keypad.
Unit
Range
Month
01 - 12
Day
01 - 31
Year
four digits required
Hour
01 - 12 (12-hour mode)
00-23 (24-hour mode)
Minute
00 - 59 NOTE: By default, the clock mode is set to the 12-hour mode; however, the clock mode can be modified to the 24-hour mode. See the Related Items below for additional information.
Press the [*] or [#] button on the numeric keypad to select 'AM' or 'PM' for the 12-hour mode.
If a mistake is made, press the [Left] or [Right] arrow button to move the cursor under the digit to be modified, and then enter the correct digit using the numeric keypad.
When the date and time are correct, press the [Enter] button.
Press the [Stop / Clear] button on the Control Panel to return to the Standby mode.
1. Press Menu until System Setup appears on the bottom line of the display and press OK. 2. Press OK when Machine Setup appears. 3. Press the Scroll buttons until Date & Time appears and press OK. 4. Enter the correct time and date using the number keypad. Month = 01 to 12 Day = 01 to 31 Year = requires four digits Hour = 01 to 12 (12-hour mode) 00 to 23 (24-hour mode) Minute = 00 to 59 Note : The date format may differ from country to country
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page.
example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
