Kenneth cole reaction
I just dug my watch out after not wearing for a few years and had the
same problem. There is an easy way to adust this watch's time and
alarm, basically one way to enter both.
1) With the watch in the
regular time display mode (doesn't matter if 12 hour or military time),
depress and hold the lower left hand button (mode button). After a few
seconds the watch appears to shift to alarm mode and it is blinking.
This puts you into the mode for adjusting the alarm.
2) If you
want to adjust time, date, etc rather than alarm time, after you have
done step one, simply press that same lower left button again, and then
it will put you into the time mode, but this time the time mode is
blinking and you can adjust the various components (seconds, minutes,
hours). You can only move minutes, hours, etc forward, no way to move
backward. You will start off with the second display blinking, probably
skip that unless you need to adjust seconds. Depress the upper right
button to shift to the next option (minutes) and you will see the
minute display blinking. Adjust the minutes by depressing the lower
right button. When finished depress upper right button to move to next
option (hours) depress the lower right button to move the
minutes/hours/month/date forward as necessary, when you finish just
press the lower left button again and it pulls you out of adjust mode
and you are back in regular time viewing.
I had to post this
because I've had this problem in the past and it killed me. Its kind of
intuititve after you get into the adjusting mode by pressing the lower
left button- remember, initially it will put you into adjust alarm
mode, but press again and you will get into adjust time mode.
Thanks heaps.
