SOURCE: Nokia 3230 USB bot working
try to download nokia 3230 pc suite again, but first delete the one that you have on your computer completely before installing the new one
SOURCE: unlock 1 GB micro sd memory card of Kingston Made
my memory card is locked .i use a nokia 3110c model. please give me the solution
SOURCE: nokia 3110 classic usb device malfunctioned
Please try connecting your phone to a different USB port other than the one which you use normally.
If the issue is the same then try connecting it to another PC if you still face the problem then it is a hardware issue.Either your phone or the USB cable is gone bad.So replace the USB cable first with a new one and then try connecting.If the issue is till the same then it is your phone and you will have to get it repaired or get it replaced if it is under warranty.
code to unlock the micro memory card 1GB of nokia 6300
