Hi, so do you have fuel,...yes, is the battery charged, yes, is the starter engaging, no? Check solenoid, if yes, is it not firing due to air in the fuel lines? Change the filter? Could be clogged, check fuses and circuit breake cb1&cb2 ! Good luck I've had this problem on my 300 d and this is what I did...have since sold it and gone to a sa 200
What are you trying to trouble shoot? If it has anything to do with electrical, equip yourself with a digital volt ohm meter (DVOM)- a necessity when dealing with low voltage circuits that vehicle computers require.
When you are doing cleaning process many times, You Purge Countergets overflown, You need to be reset the same by some technical rest code required. By pressing - menu -start - menu , Just go in reset counte and reset the same
That could be a number of things. Too much heat inside welder could also do this by creating more resistance in your leads. The easist place to start would be to take the cover off your welder and blow all the dust off your electronics so it has a way too cool properly. Make sure all power is disconnected before attempting this. Try this simple fix first. Any welding machine on the market can benefit from this simple preventative maintenance!
