Televison & Video Logo
A
Anonymous Posted on Aug 06, 2013
How do i fix my hisense 54cm colour tv the is only sound but no picture model no is tc2198l
  • Zolile Oct 06, 2018
    Looking for ic's number of hi-sense tv model no:tc2198 54cm tvl
Larry
Level 3:
  • Televison & ... Master 5,042 Answers
  • Posted on Oct 07, 2018
Larry
Level 3:
Answers
5042
Questions
Helped
1241179
Points
18413
Try the flashlight test for starters
4 Related Answers
Anonymous
  • 1779 Answers
  • Posted on Feb 27, 2008
SOURCE: hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Anonymous
  • 32 Answers
  • Posted on Mar 15, 2009
SOURCE: child locked here tv and i dont no how to unlock it
CALL THE MANUFACTURES 800 #
Anonymous
  • 14553 Answers
  • Posted on May 30, 2012
SOURCE: No sound on Hisense LTDN24V86US 24 LCD TV. Tried headphone jack still no sound.
this company has went out of business at least 2 times--They are in China and parts are for the most part non-existent.
Likely that problem is on main board (the large and most expensive board in the set.
A simple check to see if sound is present when using a DVD etc also will confirm if via rear jacks if problem in set or not.
Anonymous
  • 760 Answers
  • Posted on Mar 20, 2013
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
1helpful
2answers
Hisense TV Red Flashing Power Light Has Sound But No Picture
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
Sound and no picture on a hisense 50 in. tv model no. 50H5G
Yes but to replace all those PCB's will cost the same as a new TV in most cases. and what if it doesn't fix it or the problem is elsewhere.
Hisense crt tv tc2198L reads 115v at secondary stage but does not switch on
All the other voltages generated by the SMPS too should be checked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic diagrams along with voltages are given. Refer it, and check all of it.
How do I fix a scrambled and wavy picture on my 54cm hisense colour tv
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
1helpful
Crt standard hisense 54cm colour tv model tc2198L no powering fuse ok HOT ok.
Check the power supply.If you have no output from the power supply try to disconnect the power supply from the other circuits ( such as the IF,audio,video,horizontal,vertical,etc.If the voltage at the power supply comes up when you disconnect a particular circuit then that circuit is loading down the power supply and you would troubleshoot that circuit.If after disconnecting the other circuits and the power supply still shows zero,then you would troubleshoot the power supply.
My sansui tv 54cm show green colour on the screen no sound no pictures
The chorma IC to your tV has damaged. It should be replaced.
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
