Won't drain from hose port
Either the hose is clogged or the hose connection and interior tubing is clogged. When this happens water is diverted to the bucket. Checking the hose is easy to do. If you find no clogs there, then the clog is in the hose connection on the unit and it's interior tubing.
Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hose connection & tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow.Reconnect the hose to the unit, plug the unit in and turn the Master
ON/OFF Switch to ON. Set the humidity extraction level to 35% or
Maximum if you have a manually controlled unit. Allow the unit to run,
while you monitor the hose end for water flow. It mat take 10 to 15 minutes for water to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this information will solve the problem for you. Thanks for choosing FixYa.
