Remove the dustcover and the platter mat. There are two round holes in the platter. Have one person hold the base down. Then the second person puts their finger into both holes and give the platter a little jerk. It should come off.
Please see my answer for "
I have a pioneer pl-115d turntable. platter wont spin, and i cannot remove the platter to get tto the belt.
Thank you.
Pull up on the platter with one hand after you remove the rubber mat. Then hit the center post with a rubber mallet while pulling up on the platter with on hand just hard enough to release the platter from the post. The platter should come off.
SOURCE: Can't remove platter after removing lock washer
It should just lift off, but might be a little stiff.
SOURCE: I need help replacing the belt on a 940 turntable.
it's simple the belt goes around the platter and the motor spindle thats it!
SOURCE: I have a Pioneer PL-A35 turntable. I had the belt
the may be a 'dead spot' on the motor, try to jump start it by spinning it with your fingers several times. it's a longshot but it might work
SOURCE: motor turns feebly, not enough to make the platter
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
SOURCE: How do I remove the
Lift the rubber mat off the platter and notice the two large holes for your fingers to fit into. Simply lift the platter off the base by pulling.
