Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
Generac Guardian 15 kw overspeed fault
Attempted to start a new Generac Guardian 15 kw air cooled generator and the unit shuts down with 'overspeed' fault. I think it is running too fast. What should be my sequence of trouble shooting?
Thanks
  • Anonymous Mar 29, 2014
    just re energized my Generac Guardian RV generator but has no 12 volt
    New Friend:
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
    New Friend:
Unit will not shutdown after exercise period
Posted on May 02, 2010
  • neilr369 May 02, 2010
    Please advise what part is causing this problem.
SOURCE:
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Hello i just started my 8 kw hole house generater ran greatput my electric water heater on 26 amp draw andsmoke came out exhaust vent shut it down ran again great turned only heater on again took amp
8 kW has a 35 amp breaker on the unit. A typical hot water is 4500 watts at 240 volts = 18.75 amps on each leg. If you are measuring 26 on one side and 19 on the other it should be ok. If it is shutting down you may have a fuel problem or you may need to adjust voltage if it's too low. Which model of 8 kW is it?
Sep 07, 2014 | Generac Guardian Series 8 kW Air-cooled...
Under voltage alarm /shutdown on generac 10 kw gen.
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Sep 18, 2012 | Generac 6051 Guardian Series Air-Cooled...
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
I purchased a new Generac 20 KW air cooled standby generator. It shuts down under its excercise program and lists a low voltage fault code. I can start the unit in the manual mode and it starts and runs...
under warranty , you best have to wait the time as anything you do to fix it will void the warranty which will suit the service agent just fine
if you void the warranty he will get 2 hours travelling time plus the cost to repair time so don't touch it
Jan 05, 2018 | Generac Power Systems Generac 5522 14 Kw...
Unit shuts down from overspeed fault unit has 35 hours total run time never ran more than 2 hours 45 minutes rest is excerise time . is this problem with the 15 kw common ?
The engine throttle control is out of adjustment. It needs to be set based on the generator frequency
(60 Hz).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 22, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Apr 06, 2009 | Guardian Electrical Supplies
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
7,351 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
Craig Butler
Craig Butler
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
