The patch keeps getting bigger. there are about 1" thick vertical white lines about 2 - 3 inches apart on the screen appearing as well. but that's not seen when viewing TV. But the white patches are persistent.
SOURCE: Vertical lines on screen when viewing
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
SOURCE: I have a vertical line in the middle of my screen
Call for warenty repair,ur tuner board have problems.Or tries bring it back at were the store u buy it at.Return it exchange for another one.
Testimonial: "Thank you very much, your help is greatly appreciated. "
SOURCE: My Sony Bravia 46
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Testimonial: "Thanks for the quick response. That sure gives me an area where to look and fix it."
Did you get if retified?
not as yet I have a friend who will check it for me.....it seems as though whenever it is very cold and raining on the screen ...the whiteness (spots) tend to spread....what do you think is causing this problem, meybe moisture or something is loose?
