Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Spotty, filmy glasses
I have an 11 year old Magtag (MDB4000AWX) dishwasher that has just started to produce spotty, filming glasses. I have done all the troubleshooting, e.g., is the water hot enough, are you using a rinse aid, is the deterent enough/too much?, etc. Yesterday I ran a dishwasher cleaner through the dishwasher without dishes and then put in a ''good'' glass, but that glass too turned out spotty.
Is there something else I canj do or is it time for a new dishwasher. Thanks.
  • 423 Answers
Even if you are sending it 120 degree water from your hot water heater, if the internal heating element has failed, your will get poor cleaning, including a film on your glassware.
Replacing the heating element will almost certainly fix the problem.
Good Luck!
Posted on Apr 04, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water that is going into the dishwasher. there is a new product out specifically to solve this problem. it is called the dishwasher filtration system. it filters the water going into your dishwasher and reduces the calcium and magnesium and those minerals is the residue or film you see on your dishes. it fits right under the sink and is very affordable. you will love the way your dishes look. it even has a money back guarantee. go get it at www.dishwasherfilter.com.
Posted on Apr 14, 2009
SOURCE:
Have a Kenmore #13749k dishwasher (for the past 3 years). For the past month any glasses on the top rack are coming out either spotty or w/ a film. Any items placed on the bottom rack are coming out...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 30, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishes do not get clean. they are filmy & spotty.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Whirlpool 24 in. DU900PCD Built-in...
Why does my glass dishes look burnt or spotty
heatman101
Aug 28, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
Dishes not coming out clean
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Apr 02, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Check your hot water supply. It should be at least 125 degrees. Are the dishes spotty or still dirty with old food? Try to pre-rinse your dishes before putting them into the dishwasher. You can also run your hot water until it's nice and hot coming from the sink before turning your dishwasher on. If they're spotty, use less or better quality detergent. My guess is going to be water temperature or pressure.
Jul 03, 2009 | KitchenAid Dishwashers
Dishwasher does not clean dishes and leaves spots on everything!!
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Mar 04, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Jul 14, 2008 | Whirlpool 24 in. DU900PCD Built-in...
Samsung DM5710DT dishwasher
the problem is hard water i bet. there is a new product out that actually filters the water going into your dishwasher. this i think is awesome becasue who knows whats in the water cleaning the dishes you eat and drink with. my dishes use to be white and spotty and after the first load with the filter they came out spotless. you can get it at www.dishwasherfilter.com. you will be glad you did. oh it goes under the sink and is small and affordable.
May 25, 2008 | Samsung 24 in. DB5710DT Stainless Steel...
Dishwashers Logo
293 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
