Powerwinch Sportfish 450 Free-Fall Anchor Windlass Logo
A
Anonymous Posted on Aug 06, 2013
Windlass 450 anchor won't release - Powerwinch Sportfish 450 Free-Fall Anchor Windlass
2008 Rinker 280 windlass anchor troubleshooting
Tightening clutch on capstan should fix the problrm
Jul 14, 2019 • Boating
Spring replacement on Muir vff 600 windlass
Replacing the spring on a Muir VFF 600 windlass can be a relatively simple process if you have the proper tools and experience working with mechanical equipment. Here are some general steps to follow:
  1. Turn off the power to the windlass at the circuit breaker or disconnect the battery.
  2. Remove the motor cover from the windlass to access the spring and chain.
  3. Disconnect the chain from the gypsy and remove it from the windlass.
  4. Locate the tensioning bolt and use a wrench to loosen it. This will release tension on the spring.
  5. Use a pair of pliers or a spring tool to remove the retaining clip that holds the spring in place.
  6. Remove the old spring from the windlass and replace it with the new one.
  7. Reinsert the retaining clip to hold the new spring in place.
  8. Use a wrench to tighten the tensioning bolt and apply tension to the new spring.
  9. Reattach the chain to the gypsy and test the windlass to ensure it is working properly.
  10. Replace the motor cover and turn the power back on.
It is important to note that if you are not familiar with the windlass or do not feel comfortable performing these steps, it is best to have a professional do the work.
Dec 13, 2018 • Boating
HOW TO OPEN HARRIS GARAGE DOOR WHEN SPRING SNAPS
In such a situation replace the spring assembly and shaft that it is attached to. Then determine how many winds you need to add to the windlass for spring tension to get the door to lift. Depending how the door track it is set up the outer wheels that take up the lift cable spool about 16 to 18 inches of cable per revolution. The spring gets tensioned by sticking a length of half inch/13 mm rod into 1 of the 4 tensioning holes of the windlass that are cast into the clamping end of the spring and turning tension onto the spring by way of that windlass to lift the door once the cables are attached to the door and then clamped into the wheels, once the approximately correct lift height has been cranked into the spring.One rod would need to be left in place to hold windlass firm until the set screw is tightened. Then you can put on a hard hat, unlock the door and lift slightly- the rod will fall out if you wound the spring the correct direction.and the door should rise again with ease.
Hello, I have a lewmar Concept 1 windlass that worked fine for May/June, then on vacation in July it started cutting out. If I let it sit for a minute, it would start up again, only to quit again after...
Check the brushes and if they are short just replace them.
This will solve the problem.
There is thermal cut out which will protect the winding if its hot and will stop windlass and after cooling down it can run again.
Sprint 600 Vertical Windlass blows fuse
Is this the main fuse???
600watts motor on a 12V system drops 50amps...
You should have an 80 or even 100 amps fuse for the power cables!
Jun 15, 2017 • Boating
Powerwinch windlass not working.
Of course, first check the voltage at the connections to the windlass. Have someone operate the switch while you measure with a volt meter. If no voltage check breakers, or fuses. Heavy current devices like a windlass will often require fuses near where they connect to battery power.
A windlass requires a LOT of current to run. Not just voltage. Trace the wires from the battery connection all the way to the windlass. If possible, loosen any connections (ex; a lug with a nut or bolt) and clean with a wire brush then reconnect. Be sure to disconnect the battery while cleaning. Many times wires will corrode past the insulation. Especially if they were not tinned wire to begin with (tinned wire has a silver shine, regular copper has a copper color and typically turns dark or even black when corroded).
Since a windlass requires a lot of current, often there may be a relay near the windlass that might go bad. Listen to see if this is activating while someone operates the switch.
1helpful
I have a Lewmar Sprint 600 Windlass. It was working, however, my battires were low and there wasn't enough power to run the windlass. I think trying multiple times, I trick the breaker. I charged the...
I had the same problem this past weekend. Took the complete unit apart and found salt and all kind of moisture in the motor itself. It sure was not sealed very well from the factory. I am unable to find the motor sold separately, therefore I am taking my unit to an electric motor shop. I am guessing it will cost me about $100-$125 to get the motor reworked. It was extremely easy to take apart.
With the moisture in the motor, there was simply too much resistance for the windlass to turn, If you get your tension wrench and work the windlass back and forth, then hit the button. It should work temporarily.
Good Luck,
Tony
Apr 14, 2009 • Boating
1helpful
Creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Jul 20, 2008 • Dryers
Top Powerwinch Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Powerwinch Boating Expert? Answer questions, earn points and help others
