Question about Electric X Treme X 360 Scooter
I need a schematic for the x-treme scooter
It wont go and the blinker wont work
  • Anonymous Mar 26, 2014
    wire digram
  • 40 Answers
Check the batteries, they need at least 12+volts to run scooter. Blinker may be burned out or the wire came loose. If batteries are charged Two things That could be wrong are: Twist throttle is NO Good, Or the controller is BAD. You need a voltage tester, (Disconnect the Wiring Harnesses) and check voltages coming out of the controller(the silver BOX with lots of wires) and see if it is sending voltage to the twist throttle. Controller wires to the Twist throttle should read 4-5 volts.
(Make Sure You Unplugged That Wiring Harness) There is 4-6 wires in that Wiring Harness then find + and - test them for voltage from that Controller box wiring harness. If You get a positive reading out of that Controller wiring harness then the Twist Throttle thing is bad. If you get NO READING out of that Controller Wiring Harness Then if is BAD. Normally it will be the dead batteries or the Twist Throttle that go bad. Batteries are expensive, Twist Throttle Cheap. Good LUCK
Posted on May 10, 2009
Hi ok my problem is everything turns on with the key lights, horn,& when the motor is hooked directly to battery it works, but when hooked up how it should be thru wiring harness it doesn't when using the throttle. Blinkers, lights and horn work then but not the motor to go anywhere. Can u tell me where to gt a diagram of wiring for my scooter PLEASE and THANK YOU.
ps Also when hooking up all 3 batteries what is the series they should be in like negative to the positive etc. HELP PLESE
Posted on May 12, 2011
SOURCE:
I need a diagram of x treme electric scooter 360
Hi get in touch with SCOOTER SUPPORT.COM they might b able to help...... Cheers
Dec 25, 2016 | Electric Health & Beauty
Blinkers not working
Hi Neil, most likely the switches themselves are faulty...
if possible expose the read of a switch and short it ... Does the blinker work ?
regards
Apr 13, 2016 | Health & Beauty
After I charge my battery on my Xtreme Scooter XB-700li (I remove the battery and charge it inside the house) when I place the battery back in the bike, no power. The bike worked the day before; now...
Did you check if there is still enough fluid in the battery chambers?
Don't trow in normal water, because the battery will not appreciate. Just demineralised water will do.
Jun 24, 2014 | X Treme Scooters X-treme Xb-700li Lithium...
Why no power xtreme scooter xb-700li
Probably bad batteries.You need to explain it more otherwise nobody would know what type of problem it really is. Maybe say if you have charged it or anything useful:)
Jun 23, 2014 | X Treme Scooters X-treme Xb-700li Lithium...
Need wiring diagram for Electric X-360 scooter
How to hook wiring x treme electric scooter
Jul 21, 2012 | Electric X Treme X 360 Scooter
I need a wiring diagram for a freedom scooter. Its 36dc volts.
That scooter brand is also known under the name
"X-treme" and the one your looking for is the "XG-470" I believe. Here is a link for an owners manuel to it. Hope it helps out.
http://manuals.monsterscooterparts.com/recreational/X-Treme/owners-manual-xtreme-xg-470.pdf
Jan 11, 2009 | Electronics - Others
Electric X Treme X 360  Scooter Logo
1,805 people viewed this question
Top Electric Toys Experts
NOEL
NOEL
Lawrence Oravetz
Are you an Electric Toy Expert? Answer questions, earn points and help others
