K-D Tools KD Tools Remote Control Starter Switch Logo
A
Anonymous Posted on Aug 05, 2013
Remote starter switch handle - K-D Tools KD Tools Remote Control Starter Switch
Prostart locks and unlocks but won't start truck
Two things, Some Chev's have a security key that will only start the car when the ignition finds the ID chip in the handle of the key, when some places install remote starters they take the ID chip from the key and glue or tape it to the ignition switch so the remote starter will start the car without the key in it. I have seen some of the glue and or tape give out and the little chip falls far enough away from the ignition switch that it cannot find it and thus will not start. this is why it will work with the key in the ignition, You will have to find a service tech that knows how to remove the chip from your key handle (the plastic you turn when the key is inserted) then place it where the ignition switch can read it correctly. The ID chip is about the size of a grain of rice an is located in a small compartment in the plastic handle of the ignition key it is well hidden but a tech that has worked with this can find it. You could do the same if you get a additional key made for your car and place the key in the steering column very close to the ignition switch, but the new key can cost you in the $50 to $80 range so a tech would be a cheaper choice.
The second thing it may be is a bad isolator relay used in the remote starter, this relay is used by some more expensive remote starters to bypass the security system of the car by other means than placing the ID chip on the ignition switch. This would also need a tech to figure it out. But it should not cost more than $90 to fix by the tech, (less any cost to replace the ID chip or relay).
My 2008 dodge caravan wont start turn the key and nothing thought it was the starter. removed it and tested. tested ok put starter back in and hooked up a remote starter switch starter turns over now with...
check for a faulty starter relay but I suspect that the problem is in the ignition switch where the contacts inside the switch are not making contact
if the ignition is on and the starter is cranking the engine and the run contacts are making contact it will fire and run
check harness connections under the dash
You need to proof read your problem, confusing. Motor turning over and one starting are different. Is the remote factory? If not you need to disconnect the power to it and try again.
How can i know if my starter relay is bad on a dodge stratus 2001
IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
2answers
Truck will not start how can i tell if its a starter or selonoid
does it spin real fast without clanging and grinding against the flywheel? if so then its probably the solenoid bad. do you have to hit the starter with a hammer then it works? it is probably bad brushes or a worn motor. eather way i think you can only get a new starter and solenoid together not sold seperate. check for bad battery cables (loose).
1helpful
Getting brake on fault from viper remote start 5701
Getting brake on fault? The remote starter/alarm has a brake sutdown wire(brown) and it connects to the switched brake wire of the vehicle. This means that when the remote starter is active, depressing the brake will send 12 volts to the remote starter, shutting the system down. If the brake shutdown wire is seeing 12 volts constantly, the remote starter will never start. Either the brake sutdown wire is connected to the wrong wire at the brake switch or, there is a problem with your brake switch. When there is a faulty brake switch, the switched wire will rest at 12 volts. One sure way to tell is that the brake lights are on constantly (the bulb may have blown by now).
1helpful
96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
2helpful
2answers
Starting problem on 99 9-3 ... battery good, no fuse problem, no clicking sound from ignition, no turnover at all. sometimes starts sometimes doesnt for past 2 days... trying to have a clue before taking...
check solenoid and or key switch... try jumping out key switch and solenoid by bypassing with a remote starter button, can buy a cheap one at kragens or autozone... tap with prybar or hammer handle on starter as someone else operates key switch...
2helpful
My remote starter just stop working
IF YOU HAD IT DONE BY THE DEALERSHIP THERE SHOULD BE 2 SWITCHES ON THE DRIVER SIDE RIGHT WHERE THE INSIDE DOOR TRIM IS. IT SITS USUALLY UNDERNEATH THE HOOD LATCH RELEASE HANDLE. IN MY CAR ONE SWITCH IS RED AND THAT OPERATES THE REMOTE STARTER AND THE OTHER, BLACK ONE IS AN ALARM ON\OFF SWITCH.
Top K-D Tools Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a K-D Tools Electrical Supply Expert? Answer questions, earn points and help others
