It sounds like the wires going to the lock assembly have a break in them or the lock actuater has failed, easiest way is to run test leads from a 12 VDC source to the actuater ans see if it works if not most likely a wire has failed or if it does not work the actuater is bad and needs replaced. Thanks Don
The most likely culprit is a faulty actuator. You can test this by having someone activate the rear hatch while listening for a click or sound of some sort. If there is sound but no opening, it indicates a bad latch actuator. If there is no noise, it could be a fuse or wiring issue. You can manually unlock the door by removing the trim, but be careful around the glass latch as there are 2 push pins.
Check the wiring in the boot that runs from the body to the top of the liftgate for broken wires.
You might have to take it to a collision shop. Remove the rear hatch panel to gain access to the latch assembly if it's not responding. If you can't get it open, take it to a collision shop as they deal with these kinds of things regularly.
Door Lock System Components
The power door lock system consists of the following components:
• Driver door module (DDM)
• Passenger door module (PDM)
• Door lock relay--Located in the instrument panel (I/P) fuse block and controls the locking of the rear doors.
• Door unlock relay--Located in the I/P fuse block and controls the unlocking of the rear doors
• Body control module (BCM)
• IP BEC
• Reversible door lock actuators in each door
Driver and Passenger Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two-position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitor these inputs and send a LAN message indicating a change in the switch position. Modules, that activate the power door lock motors, receive the LAN message and activate the motor in the appropriate direction to lock or unlock the vehicle doors. The body control module (BCM) upon receipt of a lock or unlock signal will control the rear door lock or unlock relays and also send a LAN message to the DDM and PDM to perform the commanded function.
The modules that activate the power door lock motors are:
• DDM (driver door lock actuator)
• PDM (passenger front door lock actuator)
• BCM (both rear door lock actuators)
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other, causing the doors to lock or unlock.
The rear passenger doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
It's not the BCM ,more then likely it's that windows switch .
Rear Door (LH or RH) REAR POWER WINDOW SWITCH LH OR RH OPERATION WINDOW UP When the rear power window switch LH or RH is pressed in the up position Power is supplied ? through rear power window switch LH or RH terminal 4 ? to rear power window motor LH or RH terminal 2. Ground is supplied POWER WINDOW SYSTEM GW-17 C D E F G H J K L M A B GW Revision: January 2005 2004 Pathfinder Armada ? through rear power window switch LH or RH terminal 5 ? to rear power window motor LH or RH terminal 1. Then, the motor raises the window until the switch is released. WINDOW DOWN When the rear power window switch LH or RH is pressed in the down position Power is supplied ? through rear power window switch LH or RH terminal 5 ? to rear power window motor LH or RH terminal 1. Ground is supplied ? through rear power window switch LH or RH terminal 4 ? to rear power window motor LH or RH terminal 2. Then, the motor lowers the window until the switch is released. MAIN POWER WINDOW AND DOOR LOCK/UNLOCK SWITCH OPERATION WINDOW UP When the main power window and door lock/unlock switch (rear LH) is pressed in the up position Power is supplied ? through main power window and door lock/unlock switch terminal 3 ? to rear power window switch LH terminal 3 ? through rear power window switch LH terminal 4 ? to rear power window motor LH terminal 2. Ground is supplied ? through main power window and door lock/unlock switch terminal 1 ? to rear power window switch LH terminal 2 ? through rear power window switch LH terminal 5 ? to rear power window motor LH terminal 1. Then, the motor raises the window until the switch is released. When the main power window and door lock/unlock switch (rear RH) is pressed in the up position Power is supplied ? through main power window and door lock/unlock switch terminal 5 ? to rear power window switch RH terminal 3 ? through rear power window switch RH terminal 4 ? to rear power window motor RH terminal 2. Ground is supplied ? through main power window and door lock/unlock switch terminal 7 ? to rear power window motor RH terminal 2 ? through rear power window switch RH terminal 5 ? to rear power window switch RH terminal 1. Then, the motor raises the window until the switch is released. WINDOW DOWN When the main power window and door lock/unlock switch (rear LH) is pressed in the down position Power is supplied ? through main power window and door lock/unlock switch terminal 1 ? to rear power window switch LH terminal 2 ? through rear power window switch LH terminal 5 ? to rear power window motor LH terminal 1. Ground is supplied ? to main power window and door lock/unlock switch terminal 3 ? through rear power window switch LH terminal 4 ? through rear power window switch LH terminal 3 ? to rear power window motor LH terminal 1. Then, the motor raises the window until the switch is released
Gremlins ! HA HA HA sorry ! First off a little bit on how they work an what all is involved in making them work ! There are a few control modules in the mix , switches ,relays etc...
The driver door module (DDM)
The passenger door module (PDM)
The driver information center (DIC)
The rear door lock switch
The door lock relay
The door unlock relay
The liftgate lock relay--utility vehicles with liftgate only
The reversible door lock actuators in each of the doors and liftgate
Door Lock System Controls
The power door lock system can be controlled by any of the following:
A power door lock or unlock switch activation
A keyless entry transmission
An automatic door lock function
A delay lock function
Door lock cylinder switch activation
Lockout Prevention
An airbag deployment
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
The DDM (driver door lock actuator).
The PDM (passenger front door lock actuator).
The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
The first place to start is have a factory or equivalent scan tool hooked up , one that can read BCM DTC'S - diagnostic trouble codes ! This could lead to a fix faster ! Watch these three videos ! Door Locks Go Crazy 1
Do the power windows work ? DDM - driver door module fuse 15 amp - location is the instrument panel fuse box , plus LT DR circuit breaker 25 amp. Circuit breakers rarely go bad . The power locks are controlled by electronic's .The passenger side has another power supply ,that's why they still work .
• The driver door switch (DDS)
• The passenger door switch (PDS)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock/unlock relay (LBEC)
• The reversible door lock actuators in each of the doors and liftgate
The front power door lock switches are integral components of the driver door module (DDS) and passenger door module (PDS). The switches are 2 position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDS or PDS. The DDS or PDS monitors these inputs and sends a LAN message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the LAN message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock/unlock relay and also send a LAN message to the DDS and PDS to perform the appropriate function.
• The DDS (driver door lock actuator)
• The PDS (passenger front door lock actuator)
• The BCM (both rear door lock actuators and cargo door/liftgate)
The DDS and PDS are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and endgate doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. The energized the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
It's possible you have broken wire or wires inside the flex boot from the body of the vehicle to the driver's door . This happens a lot .
Fuse Block - I/P instrument panel
Left of the I/P behind the side trim panel
There is a control module in each door with connectors. I have already had one where the wiring in the connector was bad. This takes some troubleshooting, but sometimes moving things around while trying to run the windows will should you where the loose connection is.
Inspect or replace the window lock and unlock switch on the drivers door power window switch. There is a lock and unlock switch that will disable the switches to the other power window in the Jimmy. Check to make sure that switch is in the unlock position to have the other power window switch to work.
Thank you for suing fixya and good luck.
It could be the power lock motor. You could have a short or bad wiring harness. Might just be a fuse that connects to both. But since you said it's only the driver side. When the power lock motor is bad it can trigger your alarm because they're wired together.
both the rear passenger side wont unlock ???? How many doors are on the passenger side ? Or both back doors don't unlock ?
Two relays lock / unlock the back door's Not the lift gate . The BCM controls the relay's . The relay's are located in the rear fuse box . Under back seat .
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
Principles of Operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
Symptom Chart
Condition
Possible Sources
Action
All windows are inoperative
BJB Fuse:
F20.
Circuit.
Power window relay.
Front door power window switch.
GO to Pinpoint Test A .
Single power window is inoperative
Front door power window regulator.
Circuit.
Driver door power window switch.
GO to Pinpoint Test B .
Vent power window is inoperative — quarter window glass power latch
Circuit.
Quarter window glass switch.
Quarter window glass power latch.
GO to Pinpoint Test C .
The one touch down feature is inoperative
Master window regulator and door lock switch.
INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
The back window will not defrost
CJB Fuses:
F30 (10A).
F32 (20A).
F34 (20A).
BJB Fuse:
F27 (45A)
Circuit.
Heated back window switch.
SEC/timer module.
Rear window defrost relay.
GO to Pinpoint Test D .
The back window defrost will not shut off automatically
