Equity Time USA 31215 Wireless Outdoor Thermometer Logo
Anonymous Posted on Aug 05, 2013
Equity Thermometer Model 31215 How do I turn off
Equity Thermometer Model 31215 How do I turn off the "Beeping Sound"
Vernal Hastings
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 04, 2015
Vernal Hastings
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2023
Points
Press alarm button a number of times until it just shows one bell and the time. then press + button on back until all bells disappear.
1helpful
2answers
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
2answers
HOW DO I STOP THE ALARM OR CANCEL THE ALARM
Push the + button on the back of the unit until the bell symbol disappears.
Need instruction manual for equity wireless thermometer
Hi George,
I believe your Equity wireless thermometer is manufactured by LaCrosse Technology. Here is a link to their website:
http://www.lacrossetechnology.com/
From this page, you can search the type of wireless thermometer or weather station you're trying to use. (You didn't specify a model number in your request).
Also notice that there is link on that page for Support; clicking that will take you to the Manuals link. You will need to find your proper model number in the drop-down menu.
Also, there is a Contact link, so you can contact them directly for further assistance if you are unable to find your model's information.
Good luck, George! Hope this helps!
1helpful
Equity wireless thermometer instructons
1helpful
I have an Equity Weather Station model 31215B and i was wondering if the outside wireless thermometer is waterproof .
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Apr 29, 2011 • Vacuums
18helpful
2answers
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Top Equity Time USA Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you an Equity Time USA Measuring Tool and Sensor Expert? Answer questions, earn points and help others
