LG CHOCOLATE VX8500 Cellular Phone Logo
Posted on Apr 03, 2009
My screen turned white and won't change back - LG CHOCOLATE VX8500 Cellular Phone
  • Anonymous Apr 05, 2009
    my screen turn on white and dosen't work
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
632
Points
The PCB Flexible that connects the LCD Screen to the Main PCB is loose connected due to sliding movement. Unscrew the back cover of phone then use prying tool to remove you can see the PCB Flex from there, be sure not to damage the gasket on back cover housing cavity by the Ringer connector when trying to put the cover back, rf antenna signal may be affected.
My htc smartphone it will power up for a sec & then it makes the cricket sound & then it goes back to htc in white powered by angriod & its stuck on that screen HOW DO I FIXED IT PLEASE
Hi Mike, The link below is a YouTube video showing how to fix your phone, Also there's video's down the right side of the link that may help as well, BUT if that's not the issue then try the other links for white screen....CHEERS..
How To fix any Android Phone Tablet that won turn on
white screen on cell phone YouTube
Fix for Android Tablet White Screen Issue
Why can't i get back into DoubleDown casino?
maybe you got booted because you just won to many games.
Mac air white screen won,t boot
try resetting your hard drive. your screen might be going.
White screen won't turn off or close
Try pressing the power button and tapping the screen at the same time. Otherwise wait for battery to die and it should be ok when recharged.
White screen the phone won't turn off
Here is the link that might be useful, hope it helps: http://phaktor7.wordpress.com/2008/12/17/iphone-3g-white-screen-of-death-solution/
My computer screen randomly turned white and won't
Your screen might be going bad. Try plugging an another monitor and see if it works or has the same problem. If the other monitor works, it's definitely your screen is bad. If the other monitor fails and does the same thing, then the video card in the computer is bad.
I have a 6120 and every time i turn it on all i get is a white screen and nothing else how do i retreve my contact numbers from my phone memory it won,t even conect to my pc dose any one have a solution ??
You are having problem in your LCD just change your phone's LCD and everything will turn back to normal... You can Get LCD from any mobile repairing shop
2helpful
Top and bottom screens are white
Sorry for the delay. If the dsi won't turn off when you first get the white screens, hold the power button for 8 seconds. The unit should go off. Take the game cartridge out of the unit and inside that cartridge slot, is a reset button. Using a toothpick or something, press it. Turn the unit back on and it should be fine. Hope this helps :D
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
