A
Anonymous Posted on Nov 24, 2017
Now my computer does not even recognize that I have a Labtec LCS-1060 speaker attached. In the Control panel, in sounds & audio devices, it says no audio device is connected. This failure happened only yesterday (it used to work before), after I removed some installed programs in an attempt to remove one unwanted program.
Grubhead
Level 3:
  • Labtec Master 5,755 Answers
  • Posted on Nov 24, 2017
 Grubhead
Labtec Master
Level 3:
Answers
5755
Questions
Helped
1661090
Points
11417
I would use system restore to put the lost stuff back onto your computer. Then if it puts back the unwanted software be more careful about removing it.
5 Related Answers
Anonymous
  • 23 Answers
  • Posted on Sep 09, 2007
SOURCE: kinyo speakers will not work on my computer
First thing I would try is to figure out if this is a speaker problem or a system driver problem or hardware issue. First, try using headphones from an ipod and plug them into your computer and listen. Check for the input and not to mistake the miocrophone input. They should be clearly marked. If it works then its your speakers. If it does not work, you should try reloading your drivers. You can download the drivers from the company website or you may have the drivers on the system restore CD that came with the computer. Another thing to try is to reinstall the hardware. Sometimes, their is a confict when you install devices like webcams. You can verify that you do not have a problem by contacting the webcam company. Try contacting the manufacturer of the computer if it is within the last few years. Worst case, bring it in for a diagnostic to a local PC repair. Should be an inexpensive fix, less than 50.00 Hope I could help point you in the right direction Mike
Anonymous
  • 56 Answers
  • Posted on Jun 11, 2008
SOURCE: Can not hear sound
Try going to support.dell.com and entering your Service Tag. Then click on drivers and downloads and download and install the audio driver that they currently recommend for your machine. Sounds like a driver problem and something that wasn't set properly after the computer was reset.
Anonymous
  • Posted on Jul 24, 2008
SOURCE: Labtec 285 Speaker System
I have the exact same problem, what i suggest is finding your manual, and CD to install (if u have one) because i remember this problem a while back when i first got it, but after i installed it was ok...if you dont have the manual or disk, you could look for an online instalation manual (which is what im doing right now)
Anonymous
  • 8 Answers
  • Posted on Jun 06, 2009
SOURCE: My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to creative.com and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Anonymous
  • 10406 Answers
  • Posted on Nov 11, 2009
SOURCE: 2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T
> CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
No sound out of labtec lcs 1020 speakers how to plug in
On a desktop you plug them into a jack located on your sound card (varies by card model) . Laptops use the headphone jack to connect external speakers.
My labtec speaker are plugged in but still have no sound everything show it is connected but I still have no sound
WHICH OPERTING SYSTEM ???
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope it helps
Speakers make very little sound. volume turned up on computer. speakers came out of box with no manual or driver. how do I make sound louder
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
I have not sound and it tell me its not connected
if you are having problems with your sound
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Unable to get sound from speakers multimedia
you might have to uninstall then reinstall the sound drivers
if your computer came with a motherboard disk the drivers could be on it
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
My speakers quit working. my computer doesn't recognise they are even pluged in. says no audio device. i was hoping to get the exact driver for lcs-2424 so i could reinstall it
if your computer came with a disk the sounds drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
New laptop with Windows 7 does not detect Labtec LCS-1040 speakers -- is there a driver missing and if, how do I get it.
When you plug the speakers in, check that the correct default playback device has been selected
Control panel/ sound
2answers
I just hooked up my Labtec LCS-2420 speakers to my new computer and can't get any sound out of them. I can get the cheap ones that came with the computer to work, but not the Labtec. I hooked them up to...
if its a 6 channel connection its a little tricky try reconnecting your speakers that has a green connections. try playing a music while troubleshooting the connection...hope this helps..ITTech7574
2helpful
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Can't hear anything
go to start ->control panel->sound and audio devices. and click on the audio tab. under sund play back is c if your sound card is displayed in default devices if this area is grayed out, it means there is a problem with your audio device drivers. if this is the case, let me know and I'll tel you how to install the drivers.
Top Labtec Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
