Some fault with its flat cable connection. It might be damaged. Replace it with a new one. Contact any service technician. It will be the best. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
SOURCE: Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
SOURCE: How can I put the base back on my tv Sony Bravia KDL40S2000
Lay the TV face down on a flat surface covered with a cloth. Back out all the screws holding the base stand. Hold the back and front against the base shank while tightening all the screws through the base. Make sure they are tight.
SOURCE: the lower half of the tv goes black/also pastel colors
yes humidity has been known to make the panel seperate. I live in south tx and work for sony, alot of panels that show that prob is usually the panel seperating. wouldnt recomend to fix to costly around 85% the cost of when you bought it.
SOURCE: how do you take the base off the tv for wall
have you found out yet? cos im trying to do this too. the base comes off cos i put it on, but theres a leg that wont.
SOURCE: how to remove base on samsung 2333hd
We had the same problem, we just wiggled it back and forth, gave it a good tug, and hey presto! We got it out. I'm not sure whether this is the "official" method of doing it, as nothing is mentioned in the instruction manuals.
