Saws Logo
Posted on Apr 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We need the wiring configuration for the switch.
We have bought second hand Dewalt 770 10'' Powershop and new switch needs to be connected. We need wiring configuration
  • Anonymous Mar 19, 2014
    need new belt
Phil Rivera
Level 2:
Sniper:
  • Expert 83 Answers
  • Posted on Apr 03, 2009
Phil Rivera
Expert
Level 2:
Sniper:
Answers
83
Questions
Helped
112312
Points
293
Contact a dewalt service center and they should tell you over the phone which wire should go where. I see that it has 3 prongs in the parts brake down. Most of the time the wires only reach one way. Here is a link to find your local service center.
http://www.blackanddeckerservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=
tip
How to Hot-Wire Test a Cordless Drill Motor
<span><span>The power switch may not be the problem if a cordless drill stops turning on. Sometimes a bad drill motor can prevent the tool from starting, even if the switch is good. </span></span><br /><span><span>To determine the problem, the best method is to remove the switch and then hot-wire the drill motor to the drill's rechargeable battery to test it. If the motor checks out, then it's probably the switch. </span></span><br /><span><span>The steps for testing a drill motor .</span></span><br /><span><span>In addition to tools needed for dismantling the cordless drill, such as a drill/driver, <b>two</b><b> wires</b> are needed to connect the motor wires to the drill battery. </span></span><br /><br /><span><span><span style="text-decoration: underline;"><b><a></a></b></span>Hot-Wire Test a Drill Motor</b></span></span><br /><span><span><span style="text-decoration: underline;"><b><br /></b></span></span></span><br /><p><span><span>1. Remove the drill's battery and dismantle the drill.</span></span><br /><p><span><span>2. Disconnect the wires leading from the switch to the drill motor. Sometimes this means completely removing the switch. </span></span><br /><p><br /><p><span>3. Now that the motor is isolated from the switch, <b>connect </b>one of the <b>motor </b>wires <b>to </b>one of the <b>battery </b>contacts <b>using one of the two wires</b> set aside for this test.</span><br /><p><br /><p><span><span>4. <b>Connect </b>the <b>second wire </b>to the other battery contact. </span></span><br /><p><span><span>(<b><i>Note:</i></b> It does not matter which motor wire is connected to which battery contact. The orientation is not important because it is a DC motor and will only determine which direction the motor spins.)</span></span><br /><p><span><span>5. Hold the motor firmly in one hand, and then <b>complete </b>the electrical <b>circuit </b>between the battery and the motor by connecting the second wire to the the second motor wire.</span></span><br /><p><span><span><b>If</b> the <b>motor does <i>not</i> spin</b> once the second connection is made, <b>then the drill motor</b> <b>is most likely fried</b> and needs to be replaced. </span></span><br /><p><span><span>If the motor <b><i>does </i>spin </b>after completing the electrical circuit, that's a good indication that <b>the motor is</b> a <b>healthy </b>one. If the motor tests out OK but the drill is still having trouble starting up, the problem is most <b>likely </b>caused by <b>a faulty power switch</b>, not the motor.</span></span><br /><p><br /><span><br /> </span><br /><span><span>The power switch will have to be reconnected to the drill after the motor has been tested. It is important to reinstall the switch wires correctly after performing this test. </span></span><br /><span><span>The example drill used in this article has a very simple wiring configuration in its power switch. Drawing a switch wiring diagram is especially useful for switches with complicated wiring configurations.</span></span><br /><br /><span><span>If you're testing your drill's motor, chances are that some kind of part replacement is on the horizon. </span></span><span><span></span></span>
on Nov 13, 2010 • Drills
I need a drive belt for my 740 dewalt power shop arm saw
Thats a great gray vintage saw i think that parts are very hard to find I have not seen a belt driven motor of the 740 powershop because the armature is direct driven behind the sawblade.
Mar 25, 2015 • Dewalt Saws
1helpful
Blade size? for dewalt dw125 RAS
Here is the handbook download in a zip file. Should be very helpful for you.
DW 125 radial arm saw
Here is another download that may help too.
DeWalt Powershop Handbook.
May 15, 2012 • Saws
I bought new batteries for ,my dewalt dw958 drill and when I put the battery in, the drill ran for about 45 seconds then started to smoke and the drill died. The batteries are dewalt 18v xrp batteris
I am thinking the switch or motor is bad, check the switch first. you can locate parts at dewaltservicenet.com. Make a wiring diagram before removing anything, these parts are polarity sensitive.
1helpful
I need a manual for a deWalt 7740 powershop arm saw please....
you need to go to "dewaltservicenet.com" and you will need the type number I used type 4 and found the manual it is 27 pages long and you can also download the parts schematic for this tool. If I have helped you would you please vote accordingly. Thank you
Jul 13, 2011 • Saws
I need to replace the safety guard on my DeWalt 770 10" Deluxe Powershop radial arm saw. Where can I purchase it and the brackets that attach it to the saaw? I live in central Utah so I could drive up to...
The model number is 7780 and it was made by Black and Decker. The manual is here:
http://www.hammerwall.com/Manuals/Dewalt/Description/770/Dewalt%20Arm%20Saw%20Instruction%20and%20Maintenance%20Manual%201977/2271/
and here: (6.5 MB)
http://www.owwm.com/mfgIndex/pubdetail.aspx?id=2271
I would think you could get the parts from Black and Decker. Once you have the part number in hand from the manual, I am sure it is a matter of locating it via black and decker.
Kelly
Won't work anymore
switch or switch connection, fried plug.
Dec 20, 2009 • Dewalt Saws
Dewalt DW707 compound saw
Did you sense an odd smell? Try removing the brushes, there should be two, it could be one is worn too short or the connecting wire is broken.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
