If you are experiencing a keypad issue or other keys are not working. I would suggest to buy a new keypad because the old keypad might not able to reach the mother anymore. By replacing it a new keypad everything will just work fine.
Thanks.
Of course, you can change the keypad easy. You can buy an existing keypad from the your nearest cell phone dealer. Send your e-mail if our solution did solve your problem.
Buy a new phone if you realy want to fix that on you will need a new keypad it cost alot to fix maybe more then the phone itself but if you really like it you should fix it.To me its not worth fixing
Yes, they are replaceable.The keypad cover peel off and the replacement cover sticks on where the old one was.Warning!! make sure you have a new one before you remove the old one.Good Luck
nothing to worry . just go to a nearby shop & buy a new keypad. it is easy to install . just remove the front case. It is very easy to remove. after removing place the new keypad in place of it.
pls rate me
thank you
Clean the connection between the pad and mainboard, even if this does not look dirty. New pads often need cleaning due to factory residue. Use isopropyl alcohol. I had the same problem with a new keypad and this worked for me. Good luck, I hope it works for you too.
You can try and buy new keypads. You can take the keypads off by taking the whole housing off and you can it. i dont think it has anything to do with the phone. i think its just the keypads
