SOURCE: jerome harmony 4035
Most likely is that the reverse mechanism is jammed with old oil and lint to form a glue.......especially if the machine has not been used recently or regularly.
If you can remove the base plates from underneath easily, then try to operate the reverse lever, you will see a metal lever trying to move a collar around the shaft......apply a small amount of WD40 or similar to both sides of the join then press the reverse rapidly for a while, move it by hand if necessary back and forth..........with regular use this is rarely an issue, it is most common when the machine is idle for long periods.
If you cannot remove base plates easily, ie if the case is split down the middle in 2 sections, take it to a Janome Dealer who has the repair manual as trying to split the case yourself without the manual is very difficult and you will probably break the retaining clips.
www.bargainbox.com.au
SOURCE: threading bobbin
Try these instructions from the Janome website:
http://janome.com/index.cfm/LearningCenter/Techniques/General/Winding_A_Bobbin
SOURCE: SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
SOURCE: I have lost my manual for my "Harmony 8080 sewing
Online Manual
Find free instruction manuals Get your online manual here
Peeplo.com/User+Manual
