SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
SOURCE: frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
SOURCE: frigidaire side by side
Sounds very much like it is the compressor that is malfunctioning. It should still be covered by warranty by the manufacturer.
SOURCE: frigidaire dishwasher
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
SOURCE: I have a frigidaire Elite electric range.The
Take off back pane AFTER unplugging unit. there should be a fusable link, it is usually a large red wire going to the relay block, it might even say on the wire "fusable link" if it folds or bends easily it is probably blown.
