Question about Water Sport
1996 waverunner III. Will start and run for approx. 20 seconds then stop. Will not restart unless the safety lanyard is pulled then reinstalled. Starts immediately then shuts down after 15-20 seconds. Unit was turned over for approx. 5 minutes. Fuel filter changed with no improvement.
SOURCE:
  • 230 Answers
SOURCE: Brand new right out of box Everstar MPK-10CR-1 portable 10,000 BTU's
It sounds to me like it is overheating. Make sure that all of the literature that came with the unit is accounted for. Many times the manual or instructions are blocking the exhaust causing it to overheat. If this is not the problem then I would suggest exchanging it for a new one. It may be a manufacturer defect.
Posted on Jun 27, 2008
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
polarcycle
  • 1392 Answers
SOURCE: starts and runs 3-5 seconds and shuts down
Sounds like your security system is shutting the car down. You should be able to leave the key on for 15 minutes and it will reset itself. Make sure you are using factory keys, and they are in good condition.
Posted on May 28, 2009
  • 202 Answers
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Posted on Jul 07, 2009
1992 yamaha waverunner 111 wra650q Runs great until you shut it off or it shuts off? Ok as long as you restart in a few seconds it will fire instantly , if you wait 5 minutes or longer it will turn over...
Not real familiar with waverunners (this is a car and truck section after all), but remember that when you have been riding and stop engine it gets much hotter. Could possibly be coil "Heat Soak", or even a fuel system vapor lock issue caused by a pinhole leak in a line or a bad gas cap. Not very confident in this, but the best I got. Try posting in the waverunner section.
Jul 12, 2017 | Cars & Trucks
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
1995 Yamaha Waverunner III dies won't run
Check cylinder compressions, this ski will overheat if one side is low. Thus is step one, if ok and within 10% of each other, verify the exhaust isn't clogged with sand from "beaching" third verify the crank seals are not leaning the Mix causing an overheat. Obviously check the impeller housing to exhaust line isnt clogged, disconnecting the thermal sensor is asking for a top end rebuild which is about 500.00 they are designed to reduce revs and alternate spark to the cylinders once 200 degrees is reached.
Jul 31, 2012 | Water Sport
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
How do I turn the power on to my yamaha waverunner
Hi if the battery is good and the safety lanyard is connected you should have power. Hope this helps, regards Phil.
May 31, 2011 | Yamaha Boating
How do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
Jun 28, 2009 | Yamaha 12V Air Pump
HARD TO START. WILL ONLY RUN ABOUT 20 SECONDS.
Your carburetor needs cleaned. Disassemble and spray with carb. cleaner. TIP: Use a Den Tek Brush, (used for cleaning between teeth),to clean small portals in carb. check the small screen in carb. for debris. Reassemble and start. If it still doesn't run properly, buy a carb. kit and replace the small screen, needle valve, gasket(s), and diaphram. this should definitely do it.
Jim
Jun 04, 2009 | Garden
Engine Floods after brief start and run when cold -then shut off
Local mechanic determined engine was flooded and started it by holding throttle to the floor and cranking 5-7 seconds - then the engine sputtered to life. It has run perfectly before and since and I'm at a bit of loss to understand why this occurred this one time - so far. It's been driven now 5 days with no problems.
Nov 19, 2008 | 1996 Honda Odyssey
Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Jan 05, 2008 | Neff H5470 Microwave Oven
Water Sport Logo
386 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
