Question about Sony M-2000 MicroCassette Transcriber Refurbished
The sound is extremely scratchy and full of static. I know it is not the tape itself because when I listen to it on the VOR microcassette recorder it is fine. I have tried cleaning the heads with a Q-tip dipped in alcohol but it does not help. What else can I do? tks.
    Problem Solver:
  • 18 Answers
Check the headset and or the headset connection.
Posted on Jan 02, 2015
SOURCE:
Scratchy sound on turntable with mat om
One of two things. The deck has got a static problem. Perhaps caused by an earth connection problem.
Or you have a bad earth connection on the cartridge.
Dec 27, 2015 | Crosley Executive Portable USB Turntable
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
MC-60 tape says, "end of
Wow, microcassettes! (Sorry, I thought they were so cutting edge when they were.......cutting edge!)
Anyway, forgive the humour - you've most likely got a tape jam in the cassette itself but if it does this with other cassettes then you've got a dead rewind function your message indicates that you've got a later model recorder with a status display.
What does Fast Forward do?
I know it's annoying but the cheapest option may be to turn the cassette over and use FF if it works OK.
Have you checked out digital pocket recorders?
For the same money, or less, than yours likely cost new, they free you from cassettes, tape winding time, poor quality - all those analogue hassles.
The memory (time) capacity even the most bog-standard (as we say in the UK!) ones have is mind blowing.
Sep 21, 2011 | AT&T MC-60 Microcassette Tape Micro...
The voice recording fades in some parts
- Possibly the recording head may need cleaning and demagnetizing.
- The tape itself could be damaged or even folded.
- It may be also because one or both backup pads are missing on the microcassette.
There should two pads behind the tape as shown below.
May 31, 2011 | Sony M475 Handheld Cassette Voice Recorder
How do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
Jun 07, 2010 | Sony BM-850T Desktop Cassette Transcriber...
Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it...
Hi all,
I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
Turn on
Press 'M' to cycle to 'REC' mode
Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
Record as usual.
I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
If anyone knows what VOR is then please shout back.
Hope this helps.
Liam
Apr 10, 2009 | Dictaphone Walkabout 5210 Digital Voice...
The speed of the recorder
Difference between 4cm and 1.2 cm speed is just like SP and LP speed in VCR etc. 1.2 cm speed selection will give you more recording time on same cassette.
VOR stand for Voice Operated Recording, if you enable this vor option, tape starts recording only at that time when sense any voice and will remain Pause if there is silence.
This option will also give you more recording time at same cassette by skipping empty space.
Sep 17, 2008 | Sony M-675V Handheld Cassette Voice...
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Sony M-2000 MicroCassette Transcriber Refurbished Logo
732 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
