Computers & Internet Logo
Ranville King Posted on Aug 05, 2013
How do i get my HP pavilion 521n to boot DVD ?
Anonymous
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 11 Answers
  • Posted on Aug 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Night Owl:
Answers
11
Questions
Helped
1124
Points
45
  • Press the "F1" or "F10" key when the logo appears on the screen to enter the BIOS setup.
  • Navigate to the BIOS menu "Advanced" using the right/left arrow keys on your keyboard.
  • Get to the option "Boot Order" with up/down arrow keys, and press "Enter."
  • Select the first boot device under the "Boot Order menu option and press "Enter."
  • Select "DVD" from the list of available boot devices and press "Enter."
  • Press the "F10" key to save your changes and exit the BIOS setup. The computer will automatically restart and then will boot from the DVD.
  • 2 Related Answers
    Anonymous
    • 790 Answers
    • Posted on Jun 07, 2009
    SOURCE: HP pavilion dv2025nr do not boot
    Hi
    please press DEL to set the bios settings then choose the Bios set up! then click the bootable device SCSI.
    Thanks!
    Anonymous
    • 55 Answers
    • Posted on Apr 05, 2010
    SOURCE: hp pavilion dv 8000 will not boot from DVD drive or hardrive
    when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
    Can you show and identify all rear cards for the hp pavilion 521n ?
    Yes, you can check it out with some utility like Everest or Hardware Helper.
    tip
    How to Reset HP Pavilion Password on Notebook Computer
    Pavilion BIOS password reset is commonly needed. Today, we talk about HP Pavilion Windows password reset solutions. Our Windows OS users can set up administrator account and encrypt it with password to enter the OS. This actually prevents unauthorized users from operating on your system. While, if we Pavilion PC users forget the encrypted password and can't login Windows, now what to do for HP Pavilion password reset?
    Firstly, if there are not important files on our HP Pavilion notebook, we can reinstall system by deleting all data and cleaning system. Most of us may hope opt for other ways to bypass the Pavilion login password.
    Secondly, please think that is there still another account for us to enter Pavilion PC. In Windows XP, Vista, there is HP Pavilion default administrator which has blank password. For Windows 7, the built-in administrator account is disable defaulted. Only if we set it as enable, the account can be used at the moment.
    Take HP Pavilion Windows XP password reset from Safe Mode as example:
    a. Press "F8" when Pavilion laptop starts.
    b. At the "Advanced Boot Options" windows, choose "Safe Mode" with arrow key and Enter, then PC enters Safe Mode.
    c. Click "Administrator" on the Windows login screen.
    Note that if we have set this HP Pavilion administrator password, we need to input the password instead of leaving "Password" field blank.
    d. Start - Control Panel - User Accounts.
    e. Select the locked account and reset password for the locked account.
    f. Restart Pavilion laptop and login with the account newly password reset.
    Thirdly, the least troublesome solution on Pavilion password recovery is to opt for password reset program tool. With the program and a CD/DVD/USB disk, we can easily remove the password for locked computer. Take Windows Password Recovery Corporation as example:
    Step1. Burn .iso file to a CD/DVD/USB Flash Drive on an accessible PC;
    Step2. Set locked computer to boot from CD/DVD/USB Flash Drive;
    Step3. Recover forgotten Windows password with the burned CD/DVD/USB Flash Drive.
    Certainly that the 3 ways can make sure we reset Pavilion password finally. The Windows Password Recovery Corporation can be used for Windows 7, XP, Vista, and Windows Server 2003, 2008 domain password, etc.
    Source: http://windowspasswordrecovery.net/article/pavilion-password-reset.html
    Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
    Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
    Many HP machines also have a boot menu option during boot. Again an F key and may vary.
    Hp Pavilion doesn't read CD/DVDs while in OS; WinVISTA.. Solution?
    You need to go Bios setup and then reset the boot option, choose first boot as CD/DVD and then save settings and reboot now. Your issue have been resolved.
    Good Luck
    Is this service free? when i record a video on my pc, when i play back the video the sound is muffled and real low. in researching i've found that i should update software, update drivers or soundcard...
    theses are the xp drivers for the hp 521n pavilion. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=77567.
    hope this is what your after.
    My hp pavilion zd7000 wont boot up, how do I get it to turn on. Had some kind of Java virus was trying to reboot computer, and now it won't turn on at all. Computer illiterate here almost.
    hi
    becoz of virus you have re install your OS
    you have boot from Windows CD just put into ROM then restart your computer it will boot from the CD if not then you have go in bios and change boot option
    Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
    I get a err2err3 when i boot up on HP/windows vista
    i think your vista boot dvd is corrupted .just try with another one.i mean your dvd is just sort of malfunctioned because of may be more scratches.
    if find useful please rate this
    Hi
    Thanks!
    Grand Canyon Tech
    Grand Canyon Tech
