SOURCE: Port Debug LED: 50
POST 50 for Award BIOS + nForce2 chipset - usually is South Bridge problem (chip in area AGP/first PCI with name nVIDIA MCP) - integrated to him USB-controller. Chek it temperature, try press to him and start computer. If it can boot - need to burn/solder SouthBridge chip. Else - need to change (resold) this chip with another good. Another chance is Clear CMOS. If system can boot, but after Save CMOS in (BIOS Setup) POST-card stop at POST 50 again - need to change SB too. Third chance (but unlikely) - reflash BIOS with any (may be old) version. It can to do on any nVidia systems or another use LPC flash (details can read in article http://rom.by/index.php?title=Art_of_BIOS_flashing ). 1. Check temperature of South Bridge (
SOURCE: motherboard won't boot up
Hey there,
This causes if you havnt connected the power cable coming from th power button to proper jack or pin.
Check out the pin in which ur power button cable is inserted.
Does your system boot when u press the restart or shut down icon from ur windows (OS). If it is not letting ur system to boot then you've been attacked with the Worm viruses. These viruses dont let ur system to boot because they keep their process running untill ur power is off.
Gimme ur acknowladge by rating me.
Thanx.
Romy
SOURCE: epox ep-8kda3+ freezes on inital boot
Here you can find the user manual:
http://www.epox.com/USA/article.asp?ID=1731
Dont' forget to rate!
