Kitchen Ranges Logo
Posted on Apr 03, 2009
Can I use a electrical stove where a gas stove was?
I'm moving into a home that currently uses a gas stove. I have an electrical stove that I will be taking with me. Can I use this electrical stove where the gas stove was? And the electrical stove I have has 4 prongs, will I have to change out anything?
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Apr 03, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
4486
Points
46
If the oven is a 240 volt, you will have to run a dedicated electric line from your breaker box to the oven....yeas you can
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Do I need special electrical outlet?
You need to check with a licensed electrician for your area that would know the electrical codes. Most houses will all ready have an outlet for the stove and you will have to match it up with for the cord on your stove. Older homes that have not upgraded the electrical, typically will have a 3 wire outlet for the stove. Most newer homes, where the code requires, may have a 4 wire outlet. If you are replacing an existing stove I would recommend getting a new pigtail cord for the new stove so that you have new wires carrying the current instead of trusting old wires. Hope this helps!
Mar 20, 2015 • Ovens
Electrical power is off on my Hotpoint 183D6027G069, even though power is on for all other appliances and all circuit breakers checked normal.
I'm guessing this is a gas / propane stove - so the power is likely 120v if in N. America. If this is the case, I would unplug the stove and plug it into another outlet. If none is close enough, you should be able to run an extension cord to determine if it is an outlet or stove problem.
The 120v is needed on gas stoves mostly for lights, electronics, clock, ignitors, etc. It is not for heating / cook of foods so a decent cord should be fine to use. If it still refuses to function on a known to be good outlet, the power outage you had has caused a problem in the stove and will likely require service.
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
2answers
Frigidaire Stove clock resets to 12:00 when igniters turned on
local contractor came back. Said 6 other people have reported the problem according to Frigidaire.  Wasn't home so I don't know exactly what they did but they claimed to have moved some wires around.  So far no problems.  Electrical engineering friend said that they likely swapped some ground connections around so that when the ignitor draws current it doesn't drop the voltage of the whole system.  Not sure if a homeowner could troubleshoot and solve this one without directions from manufacturer.
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 • Ovens
2helpful
INSTALLING A GAS STOVE
you would need to get a LICENSED plumber for the installation of gas line. did i mention LICENSED??? its your house dont mess with a guy that tell you he's done some plumbling before
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
