While in the bath, everything seemed to be working fine until I needed to turn off the jets. They turned off but started up again on their own shortly after. After a couple instances of that, I can no longer turn the pump off with the button. I have to disconnect power at the breaker to shut off the pump. The tub is made by Kohler. I think it is probably a bad pump switch but I dont see an easy way to remove it to check/ and or replace the switch. Any suggestions on how to remove the pump switch, and do you agree that this might be the problem?
