Posted on Sep 02, 2007
Panasonic SA-PM193 5cd stereo system
CD's have started skipping and jumping during play. It happens in any of the 5 slots. I used a brush type CD cleaner but to no avail. The CD's play fine on any other system.
  • 3 more comments
  • Anonymous Dec 15, 2007
    panasonic dvd vd-70, dvd disc is not reading not only after reading it makes a line (circle) on the disc.
  • Jaggy Sodhi May 29, 2008
    SA PM 193 ---The open command does not work. I can not open the CD ports with or without remote
  • Anonymous Jun 20, 2008
    UI had posted problem regarding ports not opening, but the reply is not only inappropriate but also talks of DVD. I am facing problem with all the five music CDs.
    Please let me if you have a correct solution for SA-PM193 CD ports not opening.not opening
  • jaro114 Oct 30, 2008
    guten tag,ich sreibe aus slovakei ich kann nicht english nur duetsh sprechen ,ich habe ein problem mit mein pioneer cdj100s ,wenn ich ein cd lase ein,es kommt mir wiedeer raus,es dreht sich nicht das motor nichts ,was kann ein problem sein ,wen der laser problem ist konnen sie es reparieren ich konte ihnen schicken das player und wie fiel kostete es die reparierung.biete antworten sie mir
  • willrm Dec 11, 2008
    We have the same problem. But it does not happen until it has been playing for a little while. Sorry - no solution yet.
A
Anonymous
How do I have all 5 cd's play one after another automatically?
Lost our manual.
Thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 21 Answers
  • Posted on Sep 03, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
21
Questions
0
Helped
13314
Points
21
Bad laser can cause this.
Is the Panasonic SA-AK750 basically the same as the SC-AK750?
The versus Google query is useful
https://www.google.com/search?q=Panasonic+SA-AK750+vs+Panasonic+SC-AK750
which leads to
https://www.kleinanzeigen.de/s-anzeige/panasonic-sa-ak750-hi-fi-stereo-tape-usb-5x-cd/2580715678-172-2463
and
https://www.bhphotovideo.com/c/product/487963-REG/Panasonic_SC_K750_SC_AK750_660W_5_CD.html
And the manual explains they are the system and the main unit
System (model name) SC-AK750
Main unit (designation) SA-AK750
Front speakers SB-AK750
Subwoofer SB-WAK750
Here is the manual
Panasonic SC-AK750 Operating Instructions Manual
ManualsLib https://www.manualslib.com > manual > Panasonic-Sc-...
View and Download Panasonic SC-AK750 operating instructions manual online. Philips CD Stereo System Operating Instructions. SC-AK750 stereo system pdf ...
CD Stereo System
Panasonic https://www.panasonic.ca > ALL > rqtv0200-p
These operating instructions are applicable to the following system. System. SC-AK750. Main unit. SA-AK750. Front speakers. SB-AK750.
Here is the remote control for it.
https://www.google.com/search?q=panasonic+sa-ak750+replacement+remote+control
3answers
Panasonic SA-AK47 5 disc CD system. The volume button not working?
Service Manual, you need to test and/or replace.
Panasonic SA-AK47 Service Manual - ManualsLib
https://www.manualslib.com > manual > Panasonic-Sa-...
View and Download Panasonic SA-AK47 service manual online. SA-AK47 stereo system pdf manual download. Also for: Sb-ak47.
I have a Panasonic SA-AK 67 Can any one tell how to connect it to my phone using aux cable
Hello Zubair, to connect your phone to the SA-AK 67, you need a cable that has two RCA connectors (White and Red) to a 3.5mm stereo jack
The RCA connectors, you connect them in the AUX input that is on the rear panel of the SA-AK67 and the 3.5mm stereo jack, in the headphone output of your phone
You select Aux on the Panasonic, you play something on your cell phone and you're done
I hope you find the information useful
Greetings Franco Dosil
Hola Zubair, para conectar tu tel?fono al SA-AK 67, necesitas un cable que tenga dos conectores RCA (Blanco y Rojo) a una ficha 3,5mm est?reo
Los conectores RCA, los conectas en la entrada AUX que esta en el panel trasero del SA-AK67 y el conector 3,5mm est?reo, en la salida de auriculares de tu tel?fono
Seleccionas Aux en el Panasonic, reproduces algo en el celular y listo
Espero te sea util la informacion
Saludos Franco Dosil
http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak57 http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak77
How can I fix a slot-loading cd player that skips without taking it apart?
Look inside at the laser carriage. You should see a grooved track. Check that none of the teeth are damaged. They should be in perfect condition. If they are not the lens unit will jump during playback. It could also be caused by too much grease or dirt, or too little grease. Clean the track if you can see too much grease or dirt. If it looks dry, you can apply Silicone Grease, which you can get on-line or in electrical parts shops, such as Maplin if you are in the UK.
1helpful
When i play cds on my SonySA-VA100 system the song skips
you need to remove the lid/cover expose the laser diode use a cotton bud wipe it clean,is this your only cd player in the house? and unstable mains power coming in can cause odd things to happen with cd's. the other thing is to add some lub to the motor that drives the cd spindle,again if this does not get up to speed it wont play properly.
Recongnizing cds
no i did not fix the problem yet.sad to say but i guess i will have too seek advice else where for the fact of i wasnt willing to pay for this service.sorry for the inconvience.maybe one day i may use this service.thank you
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
 Grubhead
Grubhead
SmartAviator
SmartAviator
