Hello To deactivate the security code, Display the Security Code Setup Screen. Start to cancel a registrationof the security code. Enter a new security code. Input a four digit number as security code.
Register your security code. Now the previous security code is cleared. OK.
you just goto setting, than security, than keypad lock, & select security lock & open it.
Than you define a security code & use it.
OR
you just use third party software like keypad security lock & many more.
Reset Default
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select Reset Settings.
Scroll to and select Master Reset.
A confirmation screen will appear, select Yes.
Enter Security code, press OK.
NOTE: The default security code is 0000.
Clear memory
Scroll to and select Master Clear.
Scroll to and select desired option:
Handset
Memory Card
A confirmation screen appears, select Yes.
Enter security code, then press OK.
NOTE: By default the security code is 0000.
To unlock With-out entering the security code,
Just click on the unlock button ,then the back button frequently.
then , press the unlock button again till a * will appear on the screen
for a very short period of time, press the * button and you'll unlock the code
without entering security code.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
On the main screen , Press *#06# to get your IMEI
number,
Then just visit this website http://www.unlockme.co.uk/master.php?imei=354841017025585
And enter your IMEI code to get
your Master code.
Your Master code will help you
change your Security Code.
You can use the master code to change your security code back to what ever you
like. When your Nokia handset asks you for the security code simply enter the
master code.
button frequently.
the screen for a very short period of time, press the *
button and you'll unlock the code without entering security code.
Normal
0
false
false
false
number,
And enter your IMEI code to get your Master code. Your Master code will help you change your security code. And, When your Nokia handset asks you for the security code simply enter the master code.
Enter the Security Code, press OK. NOTE: The default security code is 0000.
Setting the PIN Code:
Scroll to and select PIN Code Request.
Scroll to and select On.
Enter the PIN code, press OK. NOTE: Default PIN code is 1111.
Changing the Security Code:
Scroll to and select Change Codes.
Scroll to and select Security Code.
Enter the current Security Code, press OK. NOTE: The default security code is 0000.
Enter in the New security code, press OK.
Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
