i have a samsung ht-db600 system when i turn it on it says hello then protection and turns offi have a samsung ht-db600 system when i turn it on it says hello then protection and turns off
AnonymousFeb 19, 2008
I have the same problem. It come on says hello than flashes protection mode and powers off.I have the same problem. It come on says hello than flashes protection mode and powers off.
AnonymousMar 23, 2008
i have the same problem, turn it on, says protection, then shuts down. please helpi have the same problem, turn it on, says protection, then shuts down. please help
AnonymousMar 26, 2008
same problem protection turns off same problem protection turns off
AnonymousMay 09, 2008
turns on for a while then says protection then turns off HELP?!!!turns on for a while then says protection then turns off HELP?!!!
AnonymousMay 20, 2008
my sharp xl dv60 system shuts off and is in protect modemy sharp xl dv60 system shuts off and is in protect mode
hello,its the LENS of your dvd player that is weak,so therefore,your dvd player cannot read disc. All you need do is just to get a new lens and get the dvd player to an authorizes repairer to fix it for you. kindly rate me if this solution is helpful.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking
noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
same problem annoying only a week old
Yup the very same problem for the HT-TZ215
same
