I would like to convert the crib to a daybed then to a full size bed with a headboard and footboard. Ive lost the instructions.
I called Jardine Enterprises and they said they would email me a manual . Call them at 1-800-295-1980 and provide them with the model number and mfg date of your crib and they will send you a manual via email.
Question, which way does the mattress support part go...The framed side up or framed side down so the top surface is flat? I ask b.c the mfg sticker says the mattress should be 27-1/4 width but my Simmons 27 inch mattress doesnt fit into the frame. I measured the mattress support part and it was only around 26 and a bit inches. There is no way my mattress would fit inside the framed mattress support..Does anyone else have this problem? Could someone measure theirs and let me know? I thought I could flip ithe mattress support part over and attach as the under side is a flat surface?? Just a thought
Were you able to convert to daybed ok? The screws seem too short to go into the board that is suppose to go across. Any suggestions? email: [email protected]
Thanks.
*Product Recall* Certain Mfg Dates for the Olympia 4 in 1 crib have been recalled. Wooden crib slats can break, creating a gap, which can pose an entrapment and strangulation hazard to infants and toddlers. http://www4.toysrus.com/safety/292475.cfm
Thank you for the recall notice our crib is on the list!
I have the same problem! I can't find the instructions to switch it to the daybed....
I have purchased the crib from Kijii but there are no set up instructions and 1 screw is missing...does anyone know if the set up manual is online?
