Tomtom Go 730 GPS Logo
Anonymous Posted on Aug 04, 2013
Navman Go 730 Screen is blank, but otherwise it
Navman Go 730 Screen is blank, but otherwise it appears to be working?
compusat
Level 2:
Sergeant:
Champion:
  • Tomtom Expert 373 Answers
  • Posted on Dec 11, 2013
compusat
Tomtom Expert
Level 2:
Sergeant:
Champion:
Answers
373
Questions
0
Helped
44827
Points
507
How to fix stuck on transfer screen
Hold down the on button until the screen goes black. wait two min, then turn it back on. If that doesn't work, try connecting your device to your computer and go online to the manufacture website. Most have a way to check your device and fix/update it.
Sep 01, 2014 • GPS
Blank screen
Sounds like your screen went bad.
Close the lid, attach an external monitor, open lid and see if the screen appears on the monitor.
Resetting the PRAM may do the trick also:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
Happy New Year,
Kerry
How do I back up my Sharp OZ 570
i change new Batteries and then not appear anythint on Screen. pls help.
1helpful
Screen is not working
check the backlight power saving settings
3helpful
Navman S reset
Please go to Preference option on your navman. From the main screen you can setup the following preferences.Now scroll to 3rd page of the prefrences.There you will see the following options:
  • Start Up – enable/disable the tutorial and language selection screen that appear when the system is switched on.
  • Saved Info – here you can delete recent locations, favourites, avoidances and reset to factory defaults.
  • Bluetooth – this option allows you to setup bluetooth pairing with a mobile phone.
  • Tutorial – run the tutorial that appears at startup.
  • Shop Demo--runs a demo so you can see the Navman S50 in action.
Just select the SAVED INFO option and then you will see a RESET TO FACTORY DEFAULT OPTION.
Jul 23, 2008 • GPS
2helpful
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
6answers
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
[email protected]
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
