Kitchen Ranges Logo
Anonymous Posted on Aug 04, 2013
WIRING DIAGRAM FOR CLOCK ON KENMORE 91194492990 ELECTRIC RANGE
Gene Pitts
Level 2:
Scholar:
  • Expert 159 Answers
  • Posted on Aug 04, 2013
Gene Pitts
Expert
Level 2:
Scholar:
Answers
159
Questions
13
Helped
78974
Points
297
You may not get the clock component level schematic but the 'Sears Parts' can provide the unit diagram. I've had great success with replacement parts and tech info.
4 Related Answers
Anonymous
  • 447 Answers
  • Posted on Oct 05, 2007
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
A
Anonymous
  • Posted on Mar 11, 2008
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Anonymous
  • Posted on Feb 08, 2009
SOURCE: need wiring diagram
Try thi site: http://www.servicematters.com/
Anonymous
  • 13 Answers
  • Posted on Oct 11, 2009
SOURCE: kenmore electric gas range oven, clock display,
Hey , there . Have you tried to reset the breaker ? I know stuppid answer but , I see it all the time . If you have 120 volts your EOC or electronic oven control is bad. 90% of the time I see a bad EOC . Or maybe a loose connection. Hope that helps .
Manual for model 790.45062401
Sears Parts Direct has the manual for the Kenmore 790.45062401 here: https://www.searspartsdirect.com/manual/69n6jkqbeh-000582/kenmore-79045062401-electric-range . Usually when a range beeps continuously, there is a communication problem between the key pad and the control board. It could indicate a short or a stuck key. That's part 20 on the backguard diagram: https://www.searspartsdirect.com/model/69n6jkqbeh-000582/kenmore-79045062401-electric-range-parts .
Since you indicate that the door lock has been triggered with the door open, try pressing the Stop/Clear button. (Note: holding the Stop/Clear button will trigger the control panel lock.) If that doesn't return the lock to the normal position, you probably have a fault in the lock mechanism. See parts 88 and on the body diagram: https://www.searspartsdirect.com/model/69n6jkqbeh-000582/kenmore-79045062401-electric-range-parts?page=3 . You can try to turn the latching rod by accessing the lock mechanism from the back of the range. (Unplug or turn the range off at the circuit breaker.) Since the lock mechanism gets a signal from the control board, check your wiring for damage. If needed, replace the lock or wiring.
I hope this helps. If your range is covered by a warranty, contact Sears/Kenmore or your extended warranty company.
Oct 25, 2019 • Ovens
I have a kenmore model 790.46893900 glass cooktop 0ven and i need to no where each of the 6 wires hook up exactly? they are the wires in clock and control digital display.
There is an old saying amongst Technicians. If you don't have a wiring diagram, mark every wire where it goes before you unplug them. The oven should have a wiring diagram somewhere behind one of the covers. If it doesn't, you may need to contact Kenmore or one of their Agents to see if they have a service manual detailing the wiring connections. Sorry , but I don't have any info on Kenmores. I don't think they are sold in Australia.
What does the code E1F2 mean on our kitchen range display
This Kenmore was built by Whirlpool. The F2-E1 error indicates a problem with the keypad wiring. Try pressing Cancel. Next make sure that the keypad is connected to the wiring harness (if it is separate from the rest of the control). You may need to replace the keypad or the entire control board (ERC or Clock).
I hope this helps.
All four top elements of my Kenmore electric stove are not heating, but the clock and lamp are working. Would you suggest what to do? Thank you very much, Arnold
First thing to do is ascertain you have 240 Volts going into the stove. Only the elements need 240 V; the rest works on 120 V. If you do have 240 V going in, you would need to find a burnt wire connection.
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
6helpful
2answers
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
This range was set for self clean. When i returned home the digital display was not on, the oven was locked, I turned on the top burners to see if they were working, they are. I tried disconnecting power...
their is a thermal fuse between the power and the main clock/timer ......find the wiring diagram ...it will be located in a small brown enevelope ....either on back../or where the range drawer.is ..remove it to look ..under either on right or left...this diagram will tell you the wire color /location on the clock/timer control..let me know an good luck.../joe/
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
