Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
A
Anonymous Posted on Aug 03, 2013
Minimum wires needed to run atv 50 - Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Silas Lawrence
Level 3:
  • Master 906 Answers
  • Posted on Jan 25, 2015
Silas Lawrence
Master
Level 3:
Answers
906
Questions
Helped
181918
Points
2158
None if you pull the plug wire to shut it down. Disconnect the wire from the magnito that goes to the ignition switch. it will run without it
2answers
2017 TaoTao 50 replace air filter
Hello. personally I will recommend 35mm AIR FILTER for Chinese made 50cc, 70cc, 90cc, 100cc, 110cc, 125cc Kids Taotao ATV, GO-KART, POCKET BIKE, DIRT BIKE
tip
AEON ATV Wiring Diagram
Aeon - one of the youngest motorcycle companies in Taiwan, established in 1998, produces a wide range of technology and scooters.
The basis of company Aeon make scooters with engines (two-stroke and four-stroke) capacity ranging from 50 to 150 cm3.
The second important direction in the activity of the company - production of four-wheel ATVs. In its program for children as compact models with two-stroke engines working volume of 50 and 100 cm3, and utilitarian models with more powerful engines - four-cylinder capacity of 125 and 180 cm3.
In 2002, Aeon also introduced an original children's motocross bike X-Boy with a 50-cc power unit skuternogo type.
Aeon_New_Sporty_125_180_Manual
Aeon_Sporty_Overland_180_Schema_electrica
SOURCE
Aeon ATV
on Dec 20, 2016 • ATVs
I put a 102mm piston on it with 11:1 compression and now when you try to start its hard to turn over. Ive put a new starter bigger battery and checked all wiring connections but nothing has helped....
STOP TRYING TO START THIS ATV!!!
..Sounds like the valves are hitting the piston!!
Did you/your mechanic check the valve to piston clearance at max valve lift/PISTON HEIGHT??..you need at least .035" (.89mm) on the intake and .060" (1.5mm) on the exhaust.- MINIMUM - . THIS IS CRITICAL!!!
11:1 is a pretty tall compression ratio. Are you racing this atv?.. one thing you will find out is that you NEED TO RUN HI-OCTANE fuel..NOT airplane fuel either (its got antifreeze and other additives you so not want to deal with)..11:1 might require a 110 OCTANE race gas to get it to run right... make SURE the timing is RIGHT!!..with this much compression the right fuel, timing, valve clearance, cam timing, etc, MUST be perfect!!!
I need to know the horsepower rating of the 8756 ice cream machine in order to match a 3 phase inverter to it
Standard is 208/230-60-3. Maximum Fuse: 45 Amps. Minimum Wire Ampacity: 3A. -220/380-50-3.
Maximum Fuse: 30 Amps. Minimum Wire Ampacity:27A.
What size breaker does the sm-11 require 2-30amp or 2-60 amp?
You will need the 2-60A breakers. 11kw is 11,000 watts. Watts = voltage X Current (amperes) If we take this formula and change it around to calculate amperes it is like this. Amperes = watts / volts amperes = 11000 watts / 240 volts This is 45.8 amperes or let us say 46 amperes. The closest breaker that you have would be a 50 amp breaker 2 pole of course . 2 - 50. If you cannot get a 2 - 50 then a 2-60 is fine. I would run with a #6 copper wire, I would check with local code to verify the wire size in your area. Make sure that the unit is grounded as well. Minimum of a #10 wire, I would also check local codes as well. Enjoy the steam!
5helpful
2answers
Butchered wiring on baja 50 atv
WWW.BAJAMOTORSPORTS.COM
CLICK ON BAJA 50 THEN ON THE RIGHT IS A LINK TO A PDA FILE OF OWNERS MANUAL WITH WIREING DIAGRAM.
GOOD LUCK
Atv wiring
WELL THEY USUALLY CONNECT TO THE IGNITION COIL
Top Quad Cycling Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Kardoc
Are you a Quad Cycling Expert? Answer questions, earn points and help others
