LG LMV2053 Microwave Oven Logo
Anonymous Posted on Apr 02, 2009
LG Microwave won't turn off
Woke up this morning and found it on. Push buttons have no effect. The only way to turn it off is to open the door or unplug it. Are these microwaves worth trying to fix?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 22, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7091
Points
8
Our LG did the same thing - called customer service and they told us the open and slam the door 10 times. It actually worked! It reset the switches somehow.
  • 1 more comment
  • Anonymous Jul 22, 2011
    I had the same problem with my LG over-the-range microwave oven and this solution really worked. Although, I had to slam the microwave door about 15 or 16 times in a row before the microwave turned off. It's now working again as it should.
  • Anonymous Jul 16, 2017
    i tried about 20 times didn't work
  • Anonymous Aug 19, 2021
    We reset the breaker and it solved the problem. Unplugging only temporarily solved the problem.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12202
Points
42
I had the same problem with whirlpool micro wave and found out that the switches were bad and replaced them and solved the problem
Joan Terese Stephens
Level 1:
  • Posted on Nov 12, 2022
Contributor
Level 1:
Answers
Questions
0
Helped
7091
Points
I am literally laughing so hard right now because Had the same problem. Slammed it pretty hard 15 times and lo and behold... We now have light that works!!!!!
Houser
Level 1:
New Friend:
  • Posted on Oct 17, 2015
Houser
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7091
Points
Just had same problem on lg lmv1813st made in may 2013. Slamming the door, hard, worked.
Microwave door won't open
Often that is due to accumulated grease on the door open button and the opening in the plastic control panel frame in which it moves.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
You can find links to helpful exploded view diagrams and part ordering help for most brands here.
I recommend that you bookmark that link to your favorites.
Sharp carousel door often won't open when I push the door release button in.
Take the cover off end take a look how the hinges are mounted on it, If they are bolted on they can be readjusted, He man, Use your brain .
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
How do I repair the door latch for a Sharp Carousel R-530ESF microwave oven? The push button won't open the door. I had to use a putty knife to push the latch up and open the door.
The service manuals are at our site here and here.
You can order parts from the Sears Parts Direct Web site image-4235112-10659157 or Encompass here.
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
When I woke up this morning, the carousel microwave oven light was on, and won't go off. And, none of the start buttons work. Can set time, power level, other settings, but not start!
Thinkind about it, if you open the door, the light is on and you canset time etc but no start function.
Check/replace the door interlock switches as I think there will be a faulty one or the small internal fuse has blown if it has two fuses.
Hope this helps.
2answers
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Starting by itself
Time for a service call. Should not turn on by itself at any cause. Circuit board is my guess. May be cheaper/easier to get new microwave. My first one lasted about 15 yrs--and the circuit board (touchpad) died. Bought new microwave oven.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
