The motor belongs to a coleman powermate air compressor model cl6506016 . It has a Magnetek century AC motor. part#7-194168.
I need the wire color configuration for the different terminals I am confused by information on side of motor that says power goes to terminals 1 & 6 but are not reversible. got me ?
ANY Ideas ? confused DOUG
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
