Hello Marcus, since you have already reset the dishwasher, confirm that the door is properly latched and try selecting a cycle. If resetting the power did not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance. I hope this information proves to be helpful in some way.
SOURCE: Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through
is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button
as well as the heat dry button and the high temp button do not work.
only button that will light up when pressed is the delay button. How
can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
SOURCE: frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
SOURCE: Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
SOURCE: My Frigidaire dishwasher will not start.
No solution, just a big thanks about that tip on holding down that 'Heat-Dry' button. Worked like a charm.
SOURCE: Frigidaire Energystar dishwasher will not start.
Press and hold the "heat dry" button until the light turns off. It is in lock mode.
Thank you for your inquiry, Robert!
From the information you have provided your Frigidaire dishwasher makes a whining noise after the water has been pumped out. This could be a potential issue with your drain pump or motor. To pinpoint the issue you would need to disassemble your dishwasher and test each component and this would best be done with a certified technician. This will help you avoid personal injury or future problems. Best of luck! -Matt
Good Afternoon friend, thanks for your post!
I understand that you are searching for the thermal fuse within your Frigidaire dishwasher, FFBD2411NS. I checked over your parts manual and was unable to locate any thermal fuse. Is your dishwasher not heating up? What issues are you having with your dishwasher? Any further information and I would be able to assist you further. -Matt
