SOURCE: Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
SOURCE: Ingesoll Rand 4000
http://air.ingersollrand.com/manuals/Default.aspx
Go here, If this helps you please vote me fixya..
thanks
SOURCE: I have an Ingersoll Rand compressor (RA5E6VA) 5 HP
that is just a compression fitting. Sometimes just replacing the tubing is enough to get a bit on it. If not you should be able to get another fitting from an indstrial supplier.
I believe that I have resolved the matter. It appears that the pressure switch has failed and needs to be replaced. The reason the tube melted was hot compressed gas was passing through the plastice tube over a period of time. Thank you all.
