Vizio E390-A1 39" 1080p 60Hz LED 2.95" ultra-slim HDTV Logo
Anonymous Posted on Aug 04, 2013
E390-a1 sound from speakers not working - Vizio E390-A1 39" 1080p 60Hz LED 2.95" ultra-slim HDTV
Chi Chu
Level 3:
  • Vizio Master 8,457 Answers
  • Posted on Aug 04, 2013
Chi Chu
Vizio Master
Level 3:
Answers
8457
Questions
0
Helped
2822451
Points
26282
Tries tv unplug replug it back like about an hour later for the tv do a resetting itself back to the factory setting,this might help to solved this problems.Check the sound setting in the tv setup Menu it to speaker out not something else.If u are using the tv speakers.If u are using sound bar system or reciever system make sure all the connections output are correct and functioning,this will solved the problems.
Vizio tv model e390-a1 no audio. Tried pc speakers logitech s120 from audio out only get hum.can I fix internal prblem myself?
check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Vizio Model E390-A1 Screen lights up white no sound . I can see the picture lightly in the background.
The t con board or the LCD panel is faulty. To confirm You have to replace the TCON board
http://electro-medical.blogspot.com/
How do I make my remote work? It was working then it stopped. I thought it was the batteries, so I bought new ones but it still wont do anything.
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Audio volume fluctuates randomly
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Why is my vizio 39 inch e390-a1 will not turn back on
Check and replace it power supply regulator board. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
No picture, no sound
Make sure it is not set on analog, game/video, or input screen.
Hook up dvd player
There are few ways to make a mistake. Just follow the COLOR coded cable, making certain Red goes to Red, etc. Look at the connector source from the player and attach the cable to the OUT from the Player to the IN on what ever you wish to attach it to.
New e390-a1 sound fluctuates from none to loud-what do we do?
sounds like a faulty amp chip, take the set in for repair or try it yourself, but if your asking this question chances are you cant repair it yourself. heat is what cause this fault in the first place, mute the tv and use external speakers 10$ at radioshack- repair to the unit may not be worth it good luck.... questions ask
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
