Syntax LT26HVE 26 in. HD-Ready LCD Television Logo
Anonymous Posted on Aug 03, 2013
Olevia 32in tv doesn't turn on and blue power light is off. The power plug is very loose. Before I would wiggle the power cord and it would come on. Now tv doesn't function at all I took the panel off the back of the tv and can see that the piece the power plug goes into is loose from the board it's supposed to be connected to. How can I fix this?
Chi Chu
Level 3:
  • Syntax Master 8,457 Answers
  • Posted on Aug 04, 2013
Chi Chu
Syntax Master
Level 3:
Answers
8457
Questions
0
Helped
2822888
Points
26282
U tries it with another new A/C power cord yet?Yes?It still have the same problems?Re glue the power socket plugin to the pc board and resolders the three prongs of steel connections pins again for electricity conductivities to the pc board.Now the tv should work again.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on May 17, 2009
SOURCE: syntax olevia lt32hv 32 inch lcd tv. power surge now no picture
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Anonymous
  • 8 Answers
  • Posted on Sep 16, 2008
SOURCE: Olevia 537H-B12 Won't Power ON
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here.
Anonymous
  • Posted on Dec 13, 2008
SOURCE: Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Anonymous
  • Posted on Dec 04, 2009
SOURCE: Olevia Hi Def tv 242TFHD, won't turn on. Power
yes the capacitors your looking for are a 1000uf , 1500 uf , and on the other side of the heatsink a 680 uf. the tops will be slightly bowled. replace those with same type !not brand!, and youll be happy.(same thing happened to me, less than 2 years old also).
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 02, 2010
SOURCE: i hav an 42
Your power supply module may have gone out.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
3helpful
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
5helpful
My Tv, Olevia LCD HD TV 242 FHD T11, will not turn on
Same thing Just happened to me ths AM. Acting Wierd then this morning fuzzy screen and poof won't come back on.
Comcast box was resetting at the exact same time and I found this online....
http://www.my3cents.com/showReview.cgi?id=18330&s=1188
1helpful
2answers
Olevia 237V: Blue panel light glows but TV does not turn on
I am working on the same issue. It is either the power supply or invertor board. Please let me know if you find anything out. did you open the tv and check the power supply for bulging caps?
1helpful
I have an olevia tv model number 542-13-11 and it will not turn on. Any suggestions would be appreciated. [email protected]
do you get a blue light on ? if you do that means you have power so..it could be the main-board is bad on the television. But if you have no blue light on the front of the television then you have no power. You could try switching the power switch on the back of the television several times and see if you get any type of blue light on the front of the tv. If you don't then try connecting the power cord to a power strip or straight to the wall.. if you still don't get power try disconnecting the power cord from the television overnight and then plug it back in and see if you get any sign of power.. if still no sign of power then the television power supply is bad and will need to be replace or repair..
Since the manuf. of OLEVIA is out of buss ..you have this 3rd party repair center that is able to provide you with a repair quote call this number 866-965-3842 the company is called Amergence Technology who is able to repair and service all OLEVIA HDTV products..
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
2answers
Olevia 32in" no power at all
After taking the screws out and removing the back, you will see a power supply(where master switch and cord connector are). Remove the 4 screws on the aluminum cover plate to gain access to the fuse. Using a voltmeter, with the power on and switch on, measure the voltage on each side of the round fuse located just behind the cord connector. If voltage is 0, fuse is good. If voltage between 115 and 125 V, replace fuse or have fuse replaced. I think it is a 6.3Ah 250V class fuse that is soldered into the board. IF YOU ARE NOT FAMILIAR WITH SOLDERING TECHNIQUES AND PRECAUTIONS, DO NOT ATTEMPT TO DO THIS. IF YOU ARE NOT FULLY AWARE OF ALL SAFETY PRECAUTIONS NECESSARY TO MAKE THIS REPAIR HAVE A QUALIFIED TECHNICIAN DO IT FOR YOU!!!!!!
If a new power supply is needed, contact me and I can point you in the right direction.
1helpful
Top Syntax Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
