SOURCE: My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :(
If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
SOURCE: Can not start pressure washer
remove the small bowl attached to the carberator. be careful not to loose the pin for the fuel float. clean the junk out of the bowl. inspect the carb for and remove any junk/gel. reassemble and start.
