Replaced fuel pump, pump wiring harness, fuel
Fuel Pump RELAY & FUSE CHECKED & DO you Have POWER "TO" Fuel Pump ? ALSO OIL Sending Unit Supplys the GROUND To Fuel Pump , This is A Saftey FEATURE that Shuts Down Fuel If ENGINE Looses OIL PRESSURE . And If This OIL Sending Unit or also Called (OIL PRESSURE SENSOR) << If It FAILS it WILL Cause What Seems Like A Fue Pump Problem But Is Rally Just The Sensor that is BAD. HOPE this Sheds Light on Your Problem !
