I want to remove the water pump from my Inglis Super Capacity Plus Royal washing machine. Machine is about 10 or 11 years old. I've removed the hoses and hold down clips, but the pump does not slide off the shaft. I don't want to force it, so could you please tell me the procedure for properly removing pump body?
I can tell the water is coming out around the steel shaft, even when turned off, and nowhere's else, so I'm assuming a pump body replacement will fix the problem.
