I need a belt diagram for a Husqvarna Lawn Mower Model LTH2042. e-mail me at [email protected]I need a belt diagram for a Husqvarna Lawn Mower Model LTH2042. e-mail me at [email protected]
AnonymousApr 13, 2009
belt keeps slipping off...is there a tention adjustment, and if so, where?belt keeps slipping off...is there a tention adjustment, and if so, where?
I just found the owners manual on the Husqvarna website. In the search field enter your model #. It shows you how to enter it.I just found the owners manual on the Husqvarna website. In the search field enter your model #. It shows you how to enter it.
AnonymousMar 16, 2014
BLADE CLUTCH SLIPS ON MY HUSQVARNA LTH 140. HOW DO I REMOVE CLUTCHBLADE CLUTCH SLIPS ON MY HUSQVARNA LTH 140. HOW DO I REMOVE CLUTCH
You can't post conmments that contain an email address.
The best way is to remove the deck from the mower. At this time you should grease the pulleys and spindles. there are four post that hold it. two on either side and one in the front. they are held by cotter pins. lower your deck level down makes it easier. you will have one engagement cable that just pops out it has a spring on it. then slide it out from the easiest side or pick the mower up and pull deck out . at this point it will be apparent where the belt goes and do your your other maintenance of cleaning and lube. factory says lube spindles every 8 hours of use.Then put it back under and re attach.
Some units have a dial style adjuster on the lower section of the dash. However, you may have to manually adjust the two rods under the unit that attaches the housing to the mower. Check this out first to see if this helps.
I need a belt diagram for a Husqvarna Lawn Mower Model LTH2248
