Tomtom XL 330 Car GPS Receiver Logo
Posted on Apr 02, 2009
Reset Is there a way to restore factory settings because my reset button isn't doing anything
Anonymous
Level 1:
  • Contributor 39 Answers
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
39
Questions
0
Helped
14615
Points
66
Tap "Reset factory settings" button to restore the factory settings to your TomTom XL. All your settings, including Favourites, your Home location, warnings for POIs and any Itineraries you have created are deleted.
Tap "Set Clock" button to select the type of clock that is shown and set the time.
manual download
go to tomtom website ----> support scroll down at the right hand side click Find downloads
hope this help
20/Apr/09
Netgear 26 router will not reboot after a storm
To perform a factory reset:
  1. Verify that your router's Power light is on.
  2. On the back of your router, locate the Restore Factory Settings or Reset button.
  3. Use a paper clip or similar object to press and hold the Restore Factory Settings or Reset button for seven seconds.
  4. Release the Restore Factory Settings or Reset button.
    Your router resets.
When you log in to your router again, use the default login credentials:
  • User Name: admin
  • Password: password
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
1helpful
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
How do you factory hard reset a apple iphone with the model number A1332 an no sim?
Hello
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Factory Reset iPhone Do it the Right Way Any Generation
1helpful
2answers
How can i reset Encore enRTR-104 router to default factory settings? When i push the reset button after few seconds begin the light nr. 4 faster to blink. When i release the button - the reset is done in...
I found these instructions for resetting the router to the defualt settings:
Use the "Backup Settings" tool to save the Broadband Router's current configuration to a file named "config.bin" on your PC. You can then use the "Restore Settings" tool to restore the saved configuration of the Broadband Router that you set before. Alternately, you can use the "Restore to Factory Defaults" tool to force the Broadband Router to perform reset and restore the original factory settings.
􀁺 Restore Factory Default
To restore the factory default settings of the Broadband Router, click on the "Restore" button.
􀁺 Backup Settings
Press the "Backup Settings" button to save the current setting in a filed "config.bin" or given filename.
􀁺 Restore Settings
To restore the backup file to the Broadband Router, enter the path and filename on the restore settings.
You can find the manual here:
http://www.encore-usa.com/us/support/ENRTR-104
1helpful
How do I do a reset
This printer doesn't support a COLD RESET
However it will set customer accessible menu settings back to factory default settings
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1. Use the (Left arrow) or the (Right arrow) button to select Service, and then press
(Select).
2. Use the (Left arrow) or the (Right arrow) button to select Restore defaults, and then
press (Select).
The device automatically restarts.
1helpful
How to reset to factory default
You can do this by following the steps..
Press the "MENU" button on the remote that came with your Polaroid television.
Step 2
Use the UP and DOWN arrow keys to navigate to the "Setup" menu and press the "OK" button on your remote.
Step 3
Select the "Factory Reset" option. Press "OK".
Step 4
Confirm that you want to restore factory settings to your television when prompted to so by pressing the "OK" button your keyboard once again.
Step 5
Wait a few seconds while the settings are restored. Your television may flicker or turn off and on.
Method #2
Step 1
Press the power button on the television or the remote to turn the device off.
Step 2
Disconnect any peripheral devices such as gaming systems, cable boxes and DVD players.
Step 3
Unplug the television for at least one hour. This will clear the television's memory and purge anything that may be keeping you from performing a factory reset.
Step 4
Restore power the television.
Step 5
Turn on the television.
Step 6
Follow steps 1-5 of method 1 to complete the factory reset.
Hope this helpout......
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
