GE Spacemaker model.
Problem unaffected by weight on turntable - just grinds and appears to stop/start. In trying to diagnose and fix, what steps should be taken. Is access from below? Temporary solution so far has been to turn off turntable to stop the noise and the problem
[No food blocking the rollers under the turntable plate]
SOURCE: Turntable Grinding Noise
It will need a new turntable motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
SOURCE: GE Profile Spacemaker Microwave - JVM1660BBC
Either the turntable motor is weak or the coupler has cracked or worn out.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
FYI, the high voltage is only 3-4000VDC but still quite lethal.
Otherwise, the previous solution is accurate.
SOURCE: ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
SOURCE: GE Spacemaker Microwave JVM1653WD004 Turntable not Working
Here is few site that should help you:
http://www.repairclinic.com/
http://www.partselect.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
