WHEN THE PHONE IS TURNED ON OPENING MUSIC CAN BE HEARD..WASN'T DROPPED..CAN RECEIVE PHONE CALLS..THE SCREEN FLICKERS EVERY NOW AND THEN..PLS HELP!
Faulty display or disply protection chips gone faulty
There could be two reasons for this problem
1. your display itself is bad or the connector is dirty. try replacing the display.
2. There are two glass IC's (display drivers) near the display connector. you will need to replace both. I had a similar problem. this seems to be a common problem with N70 phones. It can also be a manufacturing defect so better get this problem solved with a Nokia service centre. If after replacing the Ic's nothing happens then you will have to throw away your handset as the prints on the board are very fragile nowadays on these sets.
Find your solution from the list, Software & Hardware Problems Find Solutions for other Nokia Phones:
Nokia N70
Codes:
Nokia N95
Nokia N73
Nokia 6300
Nokia 6600
All the other Nokia Phones.
How do i replace the display ic.....
Replace the display ic right side coz der r 2 of it
Replace display ic right side
SOURCE: My n70 only shows white screen!!
my cell phone did the same thing, there is no solution-most likly caused by humitity, just send it in for a new cell phone.
white screen
Hi friends thanks for giving me suggestions! but somehow i have managed to solve my problem without spending any money!
Here is what i did....at first i waited for the screen to become normal (it stayed normal for a very short time), then i started a game and while playing the game i pressed the menu button which left the game open..and there it is, no more white screen..although battery charge doesn't last long but its working fine.........bottom line i have to keep a game running all the time on the background! Take care!
damn............................................... nokia n7o.. my phone...the screen blink gone.. stay white screen...gone...
Anyone out there..HELLO!!!...
urgently need help WITHOUT CASH...
Decent-Devil
When i switch on my mobile,it stays 5n 4 sumtime but if it is left undisturbed a white screen appears.If it is disturbed again a black line runs through the screen,makes 2 rounds and then the screen comes back to normal state.I amnt able to figure out y this is happening.Anyone to help me????
when I write sms my mobile screen flicker and same with call receiving pls give the solution of this problem
my n7o was white screen
my phones ic is not working it is just showing white screen
Same problem here
the same problem-WHITE SCREEN!!!!!!
