YOU TRY TO CONNECT YOUR BLUETOOTH IN FOLLOWING WAY
JUST OF BH-102 AND ON IT AGAIN WITH CONTINEU PRESSING POWER OR ON BUTTON U SEE INDICATION LIGHT GETTING FAST BLINCKING WHEN THIS INDICATION LIGHT FAST BLINKING YOU SEARCH FOR BH-102 THIS FAST BLINKING ONLY FOR SOME TIME
How to connect bluetooth headset Nokia BH-503 with Windows 7 I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows. Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop. if you want to find your bluetooth devices when you search bluetooth devices from your computer. - Turn off bluetooth headset. - Start add bluetooth devices function from your computer for search bluetooth devices. - Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink). - You will see Nokia Bluetooth BH-503 in your searching window. - select Nokia BH-503 device and click "Next" for connect the device - wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
SO!! FINALLY! Connect headset to the charger. Wait for 1-2 mins, then HOLD VOLUME UP key + SWITCH ON KEY for.. donno i waited for 30 sec, then looked at redlight and suddenly saw a GREEN LIGHT lightning, but it's so hard to see it. I'll try to do a photo.
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
Just wait for the battery to be completely drained-I did that to mine just now.after the battery is completely drained, I charged it, and it began functioning again.
hi i just had this problem what i did was make sure the nokia headset is turned off then turn it back on holding down the call answer button for 5 seconds untill the light on it flashes green then red which resets the headset then it should connect to the iphone mine didnt even need the passkey which is 0000 hope this works for you
go to the menu on your phone select manage connections turn on bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready:
press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several)
look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
Thanks sleekycupid.. Even i had a same problem just followed the steps you said. Step 1: Switch off the bluetooth device. Step 2: Charge the bluetooth device. Step 3: Then hold the device button till the green indicator blinks faster than normal. Step 4: Now try to pair the device from your mobile. Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3. Enjoy!
