Question about Dell Inspiron 530 Desktop Computer
Computer locking at startup
I have a dell inspiron 530 desktop which has started locking up as soon as you turn it on. After pressing the power button, it beeps, the Dell screen comes up, and that's it. It is frozen on the Dell screen. The motherboard in this unit is the Foxconn G33M02, and there is a single LED on it glowing which is amber. I suspect the motherboard is gacked, but I'm not a technician, so I thought I'd run it by the experts first.
Thanks for your time,
Sean
  • Anonymous Apr 16, 2009
    I have the same problem but no amber light
    Scholar:
  • 150 Answers
If the LED is glowing Amber then there is definitely something wrong with the hardware. Open up the system and check to make sure that all cables are plugged into the motherboard securely. If they are, you have faulty hardware somewhere. I would take it into a repair shop and see if they can locate the fault.
Please rate,
Thanks!
Posted on Apr 02, 2009
SOURCE:
Slow startup now that I upgraded BIOS
you can't reset bios. download the old version from DELL support.
Run cmd (as administrator, right mouse click and "run as administrator"), write cd Desktop (if u save here) and write bios name with /forceit (ex. N5010A07.exe /forceit)
Feb 15, 2014 | Dell Inspiron 530 Desktop Computer
During Startup, Dell Inspiron 530 computer goes into startup repair mode, have to run through repair mode several times, it will finally restart.
Did you install anything before you had the Repair Mode? You could hit the F8 or F9 key depending on computer and select 'Last Good/Known Configuration'.
Jul 03, 2012 | Dell Inspiron 530 Desktop Computer
Wont boot up.which button should i press to reset factory settings on powering up?inspiron 530
Factory settings are normally achieved by pressing the F8 on boot up, and choosing the option for "Repair My Computer". If this doesn't work, then CTRL+F11 should take you directly into the recovery option.
THIS LINK FROM DELL should walk you through the process.
Jul 20, 2011 | Dell Inspiron 530 Desktop Computer
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
Green LED on Dell Inspiron Desktop 530 - all OK?
Yes, on most desk top the green light in the back tells you that you have power to the cpu. Even though the unit is off it is telling you that the current supply is still there. This is a good feature if you move your unit as soon as you plug it in you know if the outlet is on or not.
Oct 17, 2009 | Dell Inspiron 530 PC Desktop
My Dell Inspiron 530 wont turn on
yes buy a power supply. I have seen hundreds of computers that have gone through storms. Remember a Dell usually uses a special power supply.
For a good deal look on ebay for your specific model, They almost always have "Buy it Now" deals.
Aug 15, 2009 | Dell Inspiron 530 Desktop Computer
Computer says too many 16 bit operations going on?
Hello Gary,
Please bootup the PC. Go to START then RUN. In the text field type in MSCONFIG press ENTER.
The System Configuration Utility Window will appear. Go to the STARTUP tab (far right). Uncheck ALL boxes EXCEPT your anti-virus programs click Apply then OK, then restart.
Jul 07, 2009 | Dell Inspiron 530 Desktop Computer
How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
I assume you use Windows Vista.....
In vista the default action of the power button is configured to sleep mode..
So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
Now you can just click the power button to shutdown your computer.
Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 Desktop Computer   Logo
925 people viewed this question
Clive
Clive
Alun Cox
